Rear end of 7R case?
This is the first 7R case I came across and I wonder if this is how they normally look at the rear end? The earlier cases I have do not have the same amount of mounting points for the cam chain guides?
Thank you for your time!
Old 02-08-2011, 08:26 AM
BURN-BROS's Avatar
What is the engine #? 911/??
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 02-08-2011, 09:30 AM
I can not find any type or serial number unfortunately.
Old 02-08-2011, 11:33 AM
356RS's Avatar
Interesting, looks like a 3.0 case but it's mag? right.
Mark Jung
Bend, OR
MFI Werks.com
Old 02-08-2011, 11:53 AM
BURN-BROS's Avatar
I have come across cases with multiple bosses, but they have never been machined. Your case appears to have been machined and plugs installed. I am not sure what the purpose of the extra bosses were for.
Burnham Performance
Old 02-08-2011, 12:04 PM
Ok, I have never seen or thought about those bosses earlier. All of the holes are machined/threaded and they all seem to have been used so I a bit curious if somebody know for what they could possibly been for?
Old 02-08-2011, 12:48 PM
BURN-BROS's Avatar
If there are no numbers then maybe it was a late 7R replacement case that, by default, is fully machined. I have not seen any pictures of an application that required the relocated guides. The 4 cam engines used the traditional ramp locations....
Burnham Performance
Old 02-08-2011, 01:12 PM
