Cam Rust Removal
Hi Guys, I have a set of cams that I keep as spares that have developed some surface rust due to condensation. What is the best way to clean these up before a store them in oil bags. Thanks, Jeff
Old 02-17-2011, 07:30 PM
faverymi's Avatar
I would use scotch guard pads until you see the machining lines or the wear lines clean.
Then bag.
Old 02-18-2011, 02:41 AM
I guess Scotch Guard would work. I just want to make sure I'm not too aggressive with the cleaning. Maybe soak them in PB Blaster first to loosen things up? Thanks, Jeff
Old 02-18-2011, 06:41 AM
