-   -   911 T 2.2 rebuild - 1971 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/595821-911-t-2-2-rebuild-1971-a.html)
ErrieKruger 08-18-2011 05:31 PM
Todd - as all the nuts show the same thread , it is not a single bolt defect. I have used an endoscope to look at the back of the bolts. They are all seated perfect and did not overturn.
In that case I received the wrong bolts. These must be 2.0 bolts in 2.2 rods.
I bought these from a reputable dealer , and as we do not live in a perfect world , I will get new ones from another source.
ErrieKruger 08-18-2011 06:11 PM
Rookie mistake # many
I can not believe I missed something like this .
http://forums.pelicanparts.com/uploa...1313715805.jpg
ErrieKruger 08-21-2011 03:28 PM
Case apart again - cleaning Loctite off casehalves must be the top rated hobby on this forum.
New bolts suppose to arrive tomorrow.
This time I will use my micrometer to make sure I receive what I paid for.
ErrieKruger 08-23-2011 05:37 PM
New rod bolts
New rod bolts received and installed - torqued to 39 Ft-Lb using oil as lubricant to overcome friction.
I will use Curil-T , Loctite 574 , Loctite 518 , and black RTV sealant to seal the case. That will cause 50% of Pelicans to agree with me. If I chose different sealants , 50% of Pelicans would have agreed.
http://forums.pelicanparts.com/uploa...1314145319.jpg
ErrieKruger 08-23-2011 05:47 PM
New ( incorrect ) bolt , and new ( correct ) bolt.
I wonder if using red loctite would have worked on the shorter bolts ? Given the hours I have spend on this , I will not take a chance.
http://forums.pelicanparts.com/uploa...1314146380.jpg
dhagood 08-23-2011 06:23 PM
Originally Posted by 356RS (Post 6201136)
Errie, Great thread on your engine assembly. One thing I see odd is the lack of threads showing on the connecting rod bolt after your torque down. That might be just the camera angle but you stated that it was just before case half's going together.
nice catch!
ErrieKruger 08-25-2011 03:52 PM
Threebond 1194 and 1104 ordered - will follow Henry's advice.
Hope to mate the case halves end of next week. That is the curse of living in an area where everthing needs to be ordered.
350HP930 08-25-2011 05:10 PM
I'm glad to see you caught this ahead of time, but you could have swapped the rods in and out of the case without disassembling it. There's a reason why they put the rod bolt nuts on the piston side after all. ;)
ErrieKruger 08-25-2011 05:21 PM
I was considering that , but because I missed something so obvious I wanted to make sure everything else is ok.
Still wonder if red loctite would have worked.
Any replies on the torque I used ?
350HP930 08-25-2011 06:00 PM
If all the threads were engaged you might have been able to get away with the mistake.
Locktite isn't highly recommended for rod bolts though.
ErrieKruger 09-01-2011 05:33 PM
Change in gameplan
Henry - following your advice. The curse of living in an area where everything needs to be ordered and takes time , received the 1194 today.
Hope to seal the halves , and do some more, in the next week.
http://forums.pelicanparts.com/uploa...1314923096.jpg
ErrieKruger 09-01-2011 05:42 PM
As this is a magnesium case , even though an alloy , Threebond 1194 would be the case sealant of choice. Casework was done by Ollie's , and I hope to be close to perfect.
I am willing to bet my left ( or both my brothers's ) , that this build will not have an oil leak.
ErrieKruger 09-03-2011 05:55 PM
My son Stephan came to visit and gave me the extra pair of hands I needed to seal the case. Used Threebond 1194 , Loctite 574 and Curil T .
I used an acid brush to apply the sealants as evenly as possible , and was able to mate and torque everything in 23 minutes.
http://forums.pelicanparts.com/uploa...1315097377.jpg
ErrieKruger 09-03-2011 06:00 PM
http://forums.pelicanparts.com/uploa...1315097845.jpg
http://forums.pelicanparts.com/uploa...1315097973.jpg
ErrieKruger 09-03-2011 06:10 PM
JE pistons and cylinders - same crank and rods - diameter increase of 2 mm.
ErrieKruger 09-03-2011 06:31 PM
Torqued through bolts without o-rings , torqued perimeter nuts , waited 5 hours , and added o-rings to through bolts one at a time and torqued to spec.
http://forums.pelicanparts.com/uploa...1315099388.jpg
ErrieKruger 09-04-2011 08:40 AM
Got a lot done yesterday -
http://forums.pelicanparts.com/uploa...1315150587.jpg
ErrieKruger 09-04-2011 10:03 AM
Pistons and cylinders installed using a 1mm copper base gasket supplied by machine shop - based on work done on cases and heads.
Clips no problem at all - used a $2 tool from ACE. Not one flyer .
Heads dry run - ordered new head nuts.
Re-ordered flywheel bolts - received the incorrect ones a few months ago , and only realized that when opening them.:mad:
ErrieKruger 09-04-2011 10:13 AM
Modified air baffles.
http://forums.pelicanparts.com/uploa...1315155925.jpg
ErrieKruger 09-04-2011 10:29 AM
I need 4 head washers , n/a from our host. As the others are perfect , it would be a waste to buy a whole set. Any suggestions ? Are there washers with the same specs and standards available at an auto shop ?
ErrieKruger 09-04-2011 10:53 AM
A post from 2009 warns against using the wrong / hardware store washers. I found and ordered 4 from another supplier. It would be silly to cut corners and risk the whole build.
Time is on my side , but my patience not.
Neilk 09-04-2011 12:45 PM
Can you show my a picture of the $2 ACE tool? I think I am a week behind you... putting my case together tomorrow morning when it will be a bit cooler.
Nice work BTW.
ErrieKruger 09-04-2011 01:37 PM
http://forums.pelicanparts.com/uploa...1315168363.jpg
Neil-
Not a quality product , but worked like a charm. I bent the prongs a tad , and that seems to do the trick.
ErrieKruger 09-06-2011 09:37 AM
Alternator and fan
Walnut shell blasting , and then powdercoating , will take care of this. Or maybe clearcoat Krylon as suggested by Henry.
http://forums.pelicanparts.com/uploa...1315326914.jpg
ErrieKruger 09-06-2011 07:41 PM
My wife out with friends for dinner - I could not make it because I had work to do.;)
http://forums.pelicanparts.com/uploa...1315363147.jpg
ErrieKruger 09-06-2011 08:18 PM
Orgasmic
The shroud had a few nicks that I filled up with fiberglass , sanded it down , cleaned everything starting with hot water and soap. Then after drying , the purple stuff , water , and isopropyl alcohol. Gave everything a sanding down with 600 grit sandpaper , and again alcohol ( at that stage I needed some myself ). Used Krylon high temp primer , and Krylon high temp engine paint.
http://forums.pelicanparts.com/uploa...1315364749.jpg
ErrieKruger 09-06-2011 09:25 PM
Walnut needed some glass beads to get through the layers of whatever was sucked in here over the years.
http://forums.pelicanparts.com/uploa...1315369283.jpg
ErrieKruger 09-06-2011 10:05 PM
Next on the list while waiting for parts - and having to spend a few days earning a living.
http://forums.pelicanparts.com/uploa...1315371763.jpg
ErrieKruger 09-08-2011 04:42 PM
http://forums.pelicanparts.com/uploa...1315524990.jpg
http://forums.pelicanparts.com/uploa...1315525071.jpg
http://forums.pelicanparts.com/uploa...1315525179.jpg
http://forums.pelicanparts.com/uploa...1315525243.jpg
ErrieKruger 09-08-2011 04:50 PM
I decided to keep to a conservative color on these.
ErrieKruger 09-08-2011 07:32 PM
Clear finish
http://forums.pelicanparts.com/uploa...1315535312.jpg
http://forums.pelicanparts.com/uploa...1315535388.jpg
ErrieKruger 09-10-2011 10:47 PM
http://forums.pelicanparts.com/uploa...1315719879.jpg
Rebuild alternator will arrive in 3 days.
ErrieKruger 09-11-2011 09:10 PM
Carrera chain tensioner update will be installed - but the idler arms are still perfect and will be used ( with the needed washers )
http://forums.pelicanparts.com/uploa...1315800155.jpg
ErrieKruger 09-12-2011 05:02 PM
A bit out of fucus
http://forums.pelicanparts.com/uploa...1315871743.jpg
http://forums.pelicanparts.com/uploa...1315871893.jpg
New head nuts
http://forums.pelicanparts.com/uploa...1315871971.jpg
ErrieKruger 09-12-2011 05:04 PM
The red spot in the photo above is blood - the sweat and tears only visible under UV light
ErrieKruger 09-12-2011 09:05 PM
http://forums.pelicanparts.com/uploa...1315886495.jpg
http://forums.pelicanparts.com/uploa...1315886597.jpg
356RS 09-13-2011 12:52 PM
Great job and thanks for all the step by step photos.
ErrieKruger 09-13-2011 02:34 PM
Mark - my reason for posting as many photo's as possible is the extra eyes that already saved me once , and also to have a full picture history of the car. It is going to get interesting when I start with the tub in a month or so.
ErrieKruger 09-13-2011 11:16 PM
http://forums.pelicanparts.com/uploa...1315980841.jpg
http://forums.pelicanparts.com/uploa...1315980929.jpg
ErrieKruger 09-13-2011 11:21 PM
http://forums.pelicanparts.com/uploa...1315981194.jpg
