Todd - as all the nuts show the same thread , it is not a single bolt defect. I have used an endoscope to look at the back of the bolts. They are all seated perfect and did not overturn.
In that case I received the wrong bolts. These must be 2.0 bolts in 2.2 rods. I bought these from a reputable dealer , and as we do not live in a perfect world , I will get new ones from another source. |
Rookie mistake # many
I can not believe I missed something like this .
http://forums.pelicanparts.com/uploa...1313715805.jpg |
Case apart again - cleaning Loctite off casehalves must be the top rated hobby on this forum.
New bolts suppose to arrive tomorrow. This time I will use my micrometer to make sure I receive what I paid for. |
New rod bolts
New rod bolts received and installed - torqued to 39 Ft-Lb using oil as lubricant to overcome friction.
I will use Curil-T , Loctite 574 , Loctite 518 , and black RTV sealant to seal the case. That will cause 50% of Pelicans to agree with me. If I chose different sealants , 50% of Pelicans would have agreed. http://forums.pelicanparts.com/uploa...1314145319.jpg |
New ( incorrect ) bolt , and new ( correct ) bolt.
I wonder if using red loctite would have worked on the shorter bolts ? Given the hours I have spend on this , I will not take a chance. http://forums.pelicanparts.com/uploa...1314146380.jpg |
Threebond 1194 and 1104 ordered - will follow Henry's advice.
Hope to mate the case halves end of next week. That is the curse of living in an area where everthing needs to be ordered. |
I was considering that , but because I missed something so obvious I wanted to make sure everything else is ok.
Still wonder if red loctite would have worked. Any replies on the torque I used ? |
If all the threads were engaged you might have been able to get away with the mistake.
Locktite isn't highly recommended for rod bolts though. |
Change in gameplan
Henry - following your advice. The curse of living in an area where everything needs to be ordered and takes time , received the 1194 today.
Hope to seal the halves , and do some more, in the next week. http://forums.pelicanparts.com/uploa...1314923096.jpg |
As this is a magnesium case , even though an alloy , Threebond 1194 would be the case sealant of choice. Casework was done by Ollie's , and I hope to be close to perfect.
I am willing to bet my left ( or both my brothers's ) , that this build will not have an oil leak. |
My son Stephan came to visit and gave me the extra pair of hands I needed to seal the case. Used Threebond 1194 , Loctite 574 and Curil T .
I used an acid brush to apply the sealants as evenly as possible , and was able to mate and torque everything in 23 minutes. http://forums.pelicanparts.com/uploa...1315097377.jpg |
JE pistons and cylinders - same crank and rods - diameter increase of 2 mm.
Torqued through bolts without o-rings , torqued perimeter nuts , waited 5 hours , and added o-rings to through bolts one at a time and torqued to spec.
http://forums.pelicanparts.com/uploa...1315099388.jpg |
Pistons and cylinders installed using a 1mm copper base gasket supplied by machine shop - based on work done on cases and heads.
Clips no problem at all - used a $2 tool from ACE. Not one flyer . Heads dry run - ordered new head nuts. Re-ordered flywheel bolts - received the incorrect ones a few months ago , and only realized that when opening them.:mad: |
I need 4 head washers , n/a from our host. As the others are perfect , it would be a waste to buy a whole set. Any suggestions ? Are there washers with the same specs and standards available at an auto shop ?
| All times are GMT -8. The time now is 09:22 PM. |
