-   -   911 T 2.2 rebuild - 1971 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/595821-911-t-2-2-rebuild-1971-a.html)
ErrieKruger 09-04-2011 10:53 AM
A post from 2009 warns against using the wrong / hardware store washers. I found and ordered 4 from another supplier. It would be silly to cut corners and risk the whole build.
Time is on my side , but my patience not.
Neilk 09-04-2011 12:45 PM
Originally Posted by ErrieKruger (Post 6235581)
Pistons and cylinders installed using a 1mm copper base gasket supplied by machine shop - based on work done on cases and heads.
Clips no problem at all - used a $2 tool from ACE. Not one flyer .
Heads dry run - ordered new head nuts.
Re-ordered flywheel bolts - received the incorrect ones a few months ago , and only realized that when opening them.:mad:
Can you show my a picture of the $2 ACE tool? I think I am a week behind you... putting my case together tomorrow morning when it will be a bit cooler.
Nice work BTW.
ErrieKruger 09-04-2011 01:37 PM
http://forums.pelicanparts.com/uploa...1315168363.jpg
Neil-
Not a quality product , but worked like a charm. I bent the prongs a tad , and that seems to do the trick.
ErrieKruger 09-06-2011 09:37 AM
Alternator and fan
Walnut shell blasting , and then powdercoating , will take care of this. Or maybe clearcoat Krylon as suggested by Henry.
http://forums.pelicanparts.com/uploa...1315326914.jpg
ErrieKruger 09-06-2011 07:41 PM
My wife out with friends for dinner - I could not make it because I had work to do.;)
http://forums.pelicanparts.com/uploa...1315363147.jpg
ErrieKruger 09-06-2011 08:18 PM
Orgasmic
The shroud had a few nicks that I filled up with fiberglass , sanded it down , cleaned everything starting with hot water and soap. Then after drying , the purple stuff , water , and isopropyl alcohol. Gave everything a sanding down with 600 grit sandpaper , and again alcohol ( at that stage I needed some myself ). Used Krylon high temp primer , and Krylon high temp engine paint.
http://forums.pelicanparts.com/uploa...1315364749.jpg
ErrieKruger 09-06-2011 09:25 PM
Walnut needed some glass beads to get through the layers of whatever was sucked in here over the years.
http://forums.pelicanparts.com/uploa...1315369283.jpg
ErrieKruger 09-06-2011 10:05 PM
Next on the list while waiting for parts - and having to spend a few days earning a living.
http://forums.pelicanparts.com/uploa...1315371763.jpg
ErrieKruger 09-08-2011 04:42 PM
http://forums.pelicanparts.com/uploa...1315524990.jpg
http://forums.pelicanparts.com/uploa...1315525071.jpg
http://forums.pelicanparts.com/uploa...1315525179.jpg
http://forums.pelicanparts.com/uploa...1315525243.jpg
ErrieKruger 09-08-2011 04:50 PM
I decided to keep to a conservative color on these.
ErrieKruger 09-08-2011 07:32 PM
Clear finish
http://forums.pelicanparts.com/uploa...1315535312.jpg
http://forums.pelicanparts.com/uploa...1315535388.jpg
ErrieKruger 09-10-2011 10:47 PM
http://forums.pelicanparts.com/uploa...1315719879.jpg
Rebuild alternator will arrive in 3 days.
ErrieKruger 09-11-2011 09:10 PM
Carrera chain tensioner update will be installed - but the idler arms are still perfect and will be used ( with the needed washers )
http://forums.pelicanparts.com/uploa...1315800155.jpg
ErrieKruger 09-12-2011 05:02 PM
A bit out of fucus
http://forums.pelicanparts.com/uploa...1315871743.jpg
http://forums.pelicanparts.com/uploa...1315871893.jpg
New head nuts
http://forums.pelicanparts.com/uploa...1315871971.jpg
ErrieKruger 09-12-2011 05:04 PM
The red spot in the photo above is blood - the sweat and tears only visible under UV light
ErrieKruger 09-12-2011 09:05 PM
http://forums.pelicanparts.com/uploa...1315886495.jpg
http://forums.pelicanparts.com/uploa...1315886597.jpg
356RS 09-13-2011 12:52 PM
Great job and thanks for all the step by step photos.
ErrieKruger 09-13-2011 02:34 PM
Mark - my reason for posting as many photo's as possible is the extra eyes that already saved me once , and also to have a full picture history of the car. It is going to get interesting when I start with the tub in a month or so.
ErrieKruger 09-13-2011 11:16 PM
http://forums.pelicanparts.com/uploa...1315980841.jpg
http://forums.pelicanparts.com/uploa...1315980929.jpg
ErrieKruger 09-13-2011 11:21 PM
http://forums.pelicanparts.com/uploa...1315981194.jpg
