-   -   911 T 2.2 rebuild - 1971 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/595821-911-t-2-2-rebuild-1971-a.html)
The Dude 09-14-2011 09:29 PM
Damn! Is that in your living room?
ErrieKruger 09-14-2011 10:24 PM
Yes sir - and the wife has to keep in spotless as I do not want any dust or other contaminants on the engine :)
piggdekk 09-15-2011 12:07 AM
:cool: :cool: :cool:
ErrieKruger 09-15-2011 04:54 PM
Still sealed -
http://forums.pelicanparts.com/uploa...1316130716.jpg
engatwork 09-15-2011 05:21 PM
yes sir - and the wife has to keep in spotless as i do not want any dust or other contaminants on the engine
lol
ErrieKruger 09-15-2011 05:42 PM
Head nut washers
:mad: Ordered and received washers , added to my inventory of " might work in future builds " , formerly know as " received the wrong stuff again ".
Does anyone out there have 4 head nut washers for a 1971 911 T ?SmileWavy
Out of frustration I tried to double up on washers , but that leads to one camshaft harder to turn than the other ( with std washers ) . Must be a torque issue.
ajwans 09-15-2011 05:46 PM
Originally Posted by ErrieKruger (Post 6249354)
Carrera chain tensioner update will be installed - but the idler arms are still perfect and will be used ( with the needed washers )
http://forums.pelicanparts.com/uploa...1315800155.jpg
I would replace those tensioner arms with the wider style, they are expensive new
but if you're any good with a lathe you could make a wide bushing/spacer combination.
Alternatively Henry at Supertec converts them.
andy
ajwans 09-15-2011 05:49 PM
Try Tom Butler (tom1394racing)
He seems to have a pretty deep stash of basic engine parts.
andy
ErrieKruger 09-15-2011 05:49 PM
Andy - that is the logic route. Will look into it.
On the other hand , I got a deadline to move my sh%t out of the house. Hard words from my woman who got tired of hospital standards and letting her friends in through the garage door.
That might give Landon the change to move his sh%t into my living room .
An engineer's wife told him if he goes to the supermark to buy a pint of milk , and if they have eggs , to buy six. He got home with 6 pints of milk , because they had eggs.
ErrieKruger 09-15-2011 07:45 PM
And I already received these.
http://forums.pelicanparts.com/uploa...1316141063.jpg
ajwans 09-15-2011 07:54 PM
You seem to be doing a real nice job on this engine, you can always build
it with the parts you have and replace them later. The tensioners were
always a weakness in these engines and the complete fix involves
switching to the wide idler arms.
andy
ErrieKruger 09-15-2011 08:12 PM
Agreed - but one has to decide when to replace all the parts ( buy a factory motor part by part ) , or take a calculated risk and use parts that has been inspected and falls into the technical criteria and specs.
I do not have a budget on this , but the learning curve is priceless.
Thanks for your reply
Errie Kruger
BTW- Go Springboks ! Never earned the yersey , but represented Northern Transvaal at school level , and South East ( now Pumas ) late 70's/early 80's
ErrieKruger 09-15-2011 09:40 PM
http://forums.pelicanparts.com/uploa...1316147957.jpg
ErrieKruger 09-15-2011 10:52 PM
http://forums.pelicanparts.com/uploa...1316152137.jpg
Just to make sure - Loctite
http://forums.pelicanparts.com/uploa...1316152203.jpg
ErrieKruger 09-16-2011 01:01 PM
New chain ramps and some cleaning
http://forums.pelicanparts.com/uploa...1316203102.jpg
http://forums.pelicanparts.com/uploa...1316203180.jpg
ErrieKruger 09-16-2011 02:44 PM
Installing the new chain ramps was not as easy as the books make it sound -
ErrieKruger 09-16-2011 06:00 PM
http://forums.pelicanparts.com/uploa...1316220771.jpg
Smooth sailing for too long. One of the few places that I re-used bolts , and one broke with hand turning. Might be a blessing in disguise - will replace them all after drilling this out. Using magnets to make sure no metal ends up in engine.
http://forums.pelicanparts.com/uploa...1316220842.jpg
ErrieKruger 09-17-2011 10:08 AM
PITA
http://forums.pelicanparts.com/uploa...1316279112.jpg
Back in business - new bolts and gasket.
http://forums.pelicanparts.com/uploa...1316279188.jpg
ErrieKruger 09-17-2011 11:10 AM
The left camshaft still too tight - Tom Butler saved me , and washers on their way. I hope that is the problem , otherwise I will take the left bank off and start again. Releasing the torque on cylinder # 2 head nuts , releases the crank. That is the cylinder I doubled up on washers - never thought it would have such a impact. I can still hand turn the shaft , but the right shaft turns freely.
ErrieKruger 09-17-2011 01:01 PM
I decided to lovingly name my engine after Rincewind's ( a caracter by Terry Pratchet ) camel - You Bastard. Very applicable , and earned over the last few days.
