A post from 2009 warns against using the wrong / hardware store washers. I found and ordered 4 from another supplier. It would be silly to cut corners and risk the whole build.
Time is on my side , but my patience not. Last edited by ErrieKruger; 09-06-2011 at 10:07 PM.. |
Nice work BTW.
Neil '73 911S targa |
![]() Neil- Not a quality product , but worked like a charm. I bent the prongs a tad , and that seems to do the trick. Last edited by ErrieKruger; 09-06-2011 at 07:47 PM.. |
Alternator and fan
Walnut shell blasting , and then powdercoating , will take care of this. Or maybe clearcoat Krylon as suggested by Henry.
My wife out with friends for dinner - I could not make it because I had work to do.
Orgasmic
The shroud had a few nicks that I filled up with fiberglass , sanded it down , cleaned everything starting with hot water and soap. Then after drying , the purple stuff , water , and isopropyl alcohol. Gave everything a sanding down with 600 grit sandpaper , and again alcohol ( at that stage I needed some myself ). Used Krylon high temp primer , and Krylon high temp engine paint.
Walnut needed some glass beads to get through the layers of whatever was sucked in here over the years.
Next on the list while waiting for parts - and having to spend a few days earning a living.
I decided to keep to a conservative color on these.
Clear finish
![]() Rebuild alternator will arrive in 3 days. |
Carrera chain tensioner update will be installed - but the idler arms are still perfect and will be used ( with the needed washers )
A bit out of fucus
![]() ![]() New head nuts
The red spot in the photo above is blood - the sweat and tears only visible under UV light
Great job and thanks for all the step by step photos.
Mark Jung Bend, OR MFI Werks.com |
Mark - my reason for posting as many photo's as possible is the extra eyes that already saved me once , and also to have a full picture history of the car. It is going to get interesting when I start with the tub in a month or so.
