A post from 2009 warns against using the wrong / hardware store washers. I found and ordered 4 from another supplier. It would be silly to cut corners and risk the whole build.
Time is on my side , but my patience not.
Old 09-04-2011, 10:53 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #101 (permalink)
Originally Posted by ErrieKruger View Post
Pistons and cylinders installed using a 1mm copper base gasket supplied by machine shop - based on work done on cases and heads.
Clips no problem at all - used a $2 tool from ACE. Not one flyer .
Heads dry run - ordered new head nuts.
Re-ordered flywheel bolts - received the incorrect ones a few months ago , and only realized that when opening them.
Can you show my a picture of the $2 ACE tool? I think I am a week behind you... putting my case together tomorrow morning when it will be a bit cooler.
Nice work BTW.
Neil
'73 911S targa
Old 09-04-2011, 12:45 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #102 (permalink)
Neil-
Not a quality product , but worked like a charm. I bent the prongs a tad , and that seems to do the trick.
Old 09-04-2011, 01:37 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #103 (permalink)
Alternator and fan
Walnut shell blasting , and then powdercoating , will take care of this. Or maybe clearcoat Krylon as suggested by Henry.
Old 09-06-2011, 09:37 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #104 (permalink)
My wife out with friends for dinner - I could not make it because I had work to do.
Old 09-06-2011, 07:41 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #105 (permalink)
Orgasmic
The shroud had a few nicks that I filled up with fiberglass , sanded it down , cleaned everything starting with hot water and soap. Then after drying , the purple stuff , water , and isopropyl alcohol. Gave everything a sanding down with 600 grit sandpaper , and again alcohol ( at that stage I needed some myself ). Used Krylon high temp primer , and Krylon high temp engine paint.
Old 09-06-2011, 08:18 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #106 (permalink)
Walnut needed some glass beads to get through the layers of whatever was sucked in here over the years.
Old 09-06-2011, 09:25 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #107 (permalink)
Next on the list while waiting for parts - and having to spend a few days earning a living.
Old 09-06-2011, 10:05 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #108 (permalink)
Old 09-08-2011, 04:42 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #109 (permalink)
I decided to keep to a conservative color on these.
Old 09-08-2011, 04:50 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #110 (permalink)
Clear finish
Old 09-08-2011, 07:32 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #111 (permalink)
Rebuild alternator will arrive in 3 days.
Old 09-10-2011, 10:47 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #112 (permalink)
Carrera chain tensioner update will be installed - but the idler arms are still perfect and will be used ( with the needed washers )
Old 09-11-2011, 09:10 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #113 (permalink)
A bit out of fucus
New head nuts
Old 09-12-2011, 05:02 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #114 (permalink)
The red spot in the photo above is blood - the sweat and tears only visible under UV light
Old 09-12-2011, 05:04 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #115 (permalink)
Old 09-12-2011, 09:05 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #116 (permalink)
356RS's Avatar
Great job and thanks for all the step by step photos.
Mark Jung
Bend, OR
MFI Werks.com
Old 09-13-2011, 12:52 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #117 (permalink)
Mark - my reason for posting as many photo's as possible is the extra eyes that already saved me once , and also to have a full picture history of the car. It is going to get interesting when I start with the tub in a month or so.
Old 09-13-2011, 02:34 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #118 (permalink)
Old 09-13-2011, 11:16 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #119 (permalink)
Old 09-13-2011, 11:21 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #120 (permalink)
