-   -   The Beautiful Puzzle: 1987 3.3L 930 EFI Build (http://forums.pelicanparts.com/911-engine-rebuilding-forum/598040-beautiful-puzzle-1987-3-3l-930-efi-build.html)
350HP930 06-26-2011 09:21 PM
Great progress Rick.
Are those new nylock fasteners on the case perimeter?
CaptainCalf 06-27-2011 05:05 AM
Yep, all new nylocks and washer all roundSmileWavy
CaptainCalf 06-30-2011 08:25 AM
3 of 6 heads on!
I got to get my hands dirty before work this morning:Dhttp://forums.pelicanparts.com/uploa...1309447512.jpg
http://forums.pelicanparts.com/uploa...1309447522.jpg
http://forums.pelicanparts.com/uploa...1309447532.jpg
CaptainCalf 07-05-2011 06:59 AM
More pics
made a little more progress this weekendSmileWavyhttp://forums.pelicanparts.com/uploa...1309874301.jpg
http://forums.pelicanparts.com/uploa...1309874314.jpg
http://forums.pelicanparts.com/uploa...1309874327.jpg
350HP930 07-05-2011 01:27 PM
Looks great Rick. Do you already have your wheel for degreeing the cams? I'm pretty sure one of the boxes I gave you contained a gauge holder block for measuring the cam lift so all you should need is the wheel and the gauge you used to measure your rod bolt stretch.
CaptainCalf 07-05-2011 04:31 PM
Yep, I found the dial gauge holder & thanks!
I've got a degreeing wheel and a few more dial gauges to choose from so I should be able to zero those super cup cams in soonSmileWavy
In the meantime, I finished up rebuilding the struts. New HD inserts & all newtie rod ends and ball joints
http://forums.pelicanparts.com/uploa...1309908439.jpg
CaptainCalf 07-07-2011 07:09 AM
Air Hole Plugs for heads
If anybody ever needs something to plug up those pesky little air holes on the exh side of the heads I have the perfect solution. A very wise ole race car builder turned me on to...Thanks! themSmileWavy
http://forums.pelicanparts.com/uploa...1310047712.jpg
JFairman 07-07-2011 07:47 AM
Pelican sells those in a kit with copper sealing washers. Some people have had them unscrew and blow out while driving. I put them in my car as tight as I dare with the threads coated with red loctite and they havn't come loose in 4 years.
Usually I only put a dab of red loctite on a corner of some bolt threads so they can still be removed without too much hassle but I used more on those hoping they stay put.
CaptainCalf 07-07-2011 07:53 AM
Good advise! I have copper washers in one of the 930 gaskits that I was also advised to use and now I'll also plan on some red locktite...Thanks,RC
CaptainCalf 07-08-2011 07:17 PM
more progress
I made a thread chaser today using an old used m10x1.5 head stud and paired with a snap-on collet it worked great.
http://forums.pelicanparts.com/uploa...1310177629.jpg
http://forums.pelicanparts.com/uploa...1310177688.jpg
I ended up with a couple of head bolts that were loose in the case so I added some green sleeve. Hope that does the job cuz timeserts wont be as easy:rolleyes:
http://forums.pelicanparts.com/uploa...1310177748.jpg
taped a new keg too:D
http://forums.pelicanparts.com/uploa...1310177549.jpg
PFM 07-08-2011 07:25 PM
Captian,
I like how you roll. Fresh keg and all.
CaptainCalf 07-08-2011 07:33 PM
Originally Posted by PFM (Post 6124820)
Captian,
Thanks PFM, it helps keep me cool in a hot FLORIDA garageSmileWavy
Schwarzeritter 07-08-2011 07:34 PM
Nice work man!
CaptainCalf 07-09-2011 01:18 PM
Fuel tank filter
Cleaned out all of the old gas today. I was glad to see there was plenty in there cuz it kept the tank from rusting. Replaced the tank filter screen and it needed it after 24 years:eek:
http://forums.pelicanparts.com/uploa...1310242651.jpg
http://forums.pelicanparts.com/uploa...1310242670.jpg
350HP930 07-10-2011 04:53 PM
So how many gallons did I appear to have left in there Rick? If it was my typical amount I would guess somewhere between 5 and 10 gallons.
I would ocasionally add a can of marvels to a tank to keep the pumps and CIS components supplied with some detergent/lube so hopefully that helped to prevent corrosion and gunk build up in the fuel system.
CaptainCalf 07-10-2011 06:54 PM
There was approximately 6 gallons in there and it was high octane smeely stuff that I gave to a friend for his burn pile starter;)
Changed out the fuel line between the pump and tank cuz it was loose and had hardened, but overall the fuel system looks good to go...ThanksSmileWavy
CaptainCalf 07-11-2011 05:27 PM
Distributor MIA
Found this distributor plug for an Italian motorcycle that fit well and looks great:D
http://forums.pelicanparts.com/uploa...1310430361.jpg
http://forums.pelicanparts.com/uploa...1310430391.jpg
http://forums.pelicanparts.com/uploa...1310430407.jpg
jsveb 07-11-2011 07:46 PM
Where do I buy that beer? :)
Really nice progress.
Good luck.
CaptainCalf 07-12-2011 05:23 AM
Good luck.
Thanks JesperSmileWavy
As for the beer, I have a good friend that I've been riding road bikes with for the last 15 years who's a Miller distributor in Tampa, FL. Whenever my kegerator runs dry he sends me a list of about 100 craft beers that they have in stock at that time and I just pick one and he brings it to my house. We then proceed to tap it and taste test ithttp://forums.pelicanparts.com/support/smileys/wat6.gif
350HP930 07-12-2011 06:00 AM
Good find on the distributor plug Rick.
