Did some head and cylinder measurements tonight to make sure I have room for Fire Rings...http://forums.pelicanparts.com/uploa...1300930139.jpg
http://forums.pelicanparts.com/uploa...1300930153.jpg http://forums.pelicanparts.com/uploa...1300930161.jpg There seems to be plenty of room around the head at approx. 8 to 8.5mm or 0.315 to 0.335" in width |
Cylinder Height
The cylinder height was approx. 2.5 to 3mm or 0.980 to 0.118"http://forums.pelicanparts.com/uploa...1300930435.jpg
http://forums.pelicanparts.com/uploa...1300930444.jpg |
Wiped the crank down. Now I've gotta blow out oil passages, measure clearances and track down all those bearings:)
http://forums.pelicanparts.com/uploa...1300970327.jpg |
The bigger question becomes once you decide to go with sealing rings is who will you pick to do the machine work. |
crank
One more thing to consider if its not done is to cross drill the #4 main journal and machine a full groove bearing to cure the oiling issue with rods 2 & 5, we can do that here as well, we drill out the alum. galley plugs and tap them for removable plugs as well.
Mike Bruns JBRacing.com |
I'll bring the crank with me too. It's not a case of while you were in there but more about the fact that I want this build to be bullet proof:cool: |
show your bikes if you gott'm
Side note:)
How many bike riding builders to we heave out there?http://forums.pelicanparts.com/uploa...1300983025.jpg http://forums.pelicanparts.com/uploa...1300983049.jpg http://forums.pelicanparts.com/uploa...1300983068.jpg |
Looks like the color scheme of the 930 will match up nicely with a couple of your two wheelers, lol.
True, but it looks so good, lol.
As long as you have Mike helping out you might also want to concider having him drill out the plugs in the cases so you can make sure the main oil gallies are all perfectly clean. Since the cases have been sitting a while you may want to consider replacing the squiters as well. |
Will do!
Thanks, Tony Quote:
bearings r us
bearings anyone or Stone IPA?http://forums.pelicanparts.com/uploa...1301014095.jpg
All of the above I say !
new case bonding techique
just install case through bolts and let it sit 5 yrs...no sealant required:)http://forums.pelicanparts.com/uploa...1301020394.jpg
more pics
Glad to see all the bearings held up well in their packaging despite sitting around in the florida humidity for the last several years. |
rocker locks
Anybody running these TurboKraft rocker locks? Looks like a great idea to me...http://forums.pelicanparts.com/uploa...1301060796.jpg
http://forums.pelicanparts.com/uploa...1301060812.jpg |
Wow, looks like a good solution to secure the shafts and keep them from leaking.
My only condern from a technical standpoint would be is the width of the housing casing consistant enough to where they all clamp down on the rocker shaft securely enough? |
| All times are GMT -8. The time now is 12:45 PM. |
