Is 2.4 distributor ok for 2.7 with Webers?
Just installed Webers on a 2.7 (from CIS). I understand I have to have the distributor recurved or it won't work right. Will a 2.4 distributor be ok? What are the issues with the 2.7 CIS distributor? Would 2.2T cams be an ok upgrade on the CIS cams to make this all work better?
thanks in advance
best regards
Marlin
Marlin Ness
sadly no longer: 1967 912, 1971 911T, 1974 911 Targa, 1975 914, 1972 914 Eagle GT with V8
currently: 1972 914 Eagle GT with 3.2 Carrera, 1970 911T (964 turbo wide body look), 1986 911 Carrera
Old 04-12-2011, 08:02 PM
The distributor will do fine. Not much difference between applications except maybe the Carrera mechanical injection distributor. More is based on the cam action.
Bruce
Old 04-13-2011, 06:19 PM
2.4 dizzy works great with carbs on a 2.7 engine. 911T cams will not work with CIS pistons
Old 04-19-2011, 10:46 AM
thank you both very much. the current distributor did not seem to work correctly. will try a 2.4 dizzy this weekend. Next step if this doesn't work will be to send the dizzy to Barry Hershon to be rebuilt.
thanks
Marlin
Marlin Ness
Old 04-20-2011, 08:42 PM
