Chain fence eating turbo
Are the intake insulators on a C3.2L reusable?
Or were they supposed to come new in the rebuild kit?
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 05-14-2011, 07:07 AM
abit off center
cgarr's Avatar
I reused mine as long as they are not cracked. You get a new gasket on each side.
______________________
Craig
G2Performance
Old 05-14-2011, 07:39 AM
Thanks Craig.
Old 05-14-2011, 08:12 AM
Spiderman
Jesse16's Avatar
When I did my 87 this past winter, I noticed a couple of small chunks had come off one of the insulators sharp edges and then when I pushed a little on the edges of a couple, they kinda crumbled. I bought new, they weren't in my top end kit. Check yours out carefully to make sure they're in good condition. I'd recommend maybe you consider replacing 23 year old plastic with new. You might not see the crack when you tighten down and then you have an intake leak.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 05-17-2011, 05:55 AM
Yeah, I had 3 perfect ones and 3 really flaky ones. I assume the massive oil leak rotted the three.
Old 05-17-2011, 09:59 AM
