Adhesive to use......
What would be a good adhesive to use to keep the chain ramp stud in place? Found the missing stud at the bottom of the chain housing during engine tear down. Would JB Weld, red loctite, etc. be a good adhesive for this type of work? Any suggestion, recommendation, or tip much appreciated.
Thanks, Tony
Old 05-17-2011, 12:10 PM
abit off center
cgarr's Avatar
Those are an interference fit or press fit. Not sure if they make an oversize? I don't think bonding it in will work..but I could be wrong.
______________________
Craig
G2Performance
Old 05-17-2011, 12:30 PM
j911brick's Avatar
Knowing me, I would try JB weld.What do you have to lose?
james
www.gruppe9autowerks.com
Its not how fast you go...its how you go fast
Old 05-22-2011, 07:49 PM
OldTee's Avatar
Buy a used chain housing. I will be cheaper and less trouble in the long run.
Old Tee
all 911s sold
Old 05-23-2011, 05:10 AM
Did that.......
OldTee,
Purchased one from Tom Butler and should arrive tomorrow according to tracking number. Since I'm rebuilding this motor for a Pelican member, I decided to take a more prudent course of action. Thanks.
Tony
Old 05-23-2011, 08:02 PM
