cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
over sized bearings
Does anyone have a source to get bearings that are one over sized (.25mm inner diameter). Need them for the crank and rods. The ones I have found are close to $1000.
come on, $1000 for a curved piece of metal? There has to be an aftermarket of some source I am missing to get them cheaper. Regular ones are $50
Thanks,
Chris
73 911 E
Old 07-05-2013, 06:57 AM
You are not missing anything,....no aftermarket sources for O/S rod & main bearings for the 2.7's & smaller engines.
This is why we machine the cases when they need O/S mains.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 07-05-2013, 09:09 AM
docrodg's Avatar
I was able to get some for my case that had been linebored by motorsheister for oversized bearings from ollies. as i recall wasabout 350 buckss for the set.
1968 911S "Leona"
Air goes in and out, blood goes round and round, any variation on this is a bad thing.
Old 07-05-2013, 11:17 AM
cmcfaul's Avatar
My machine shop guy says he has a standard / standard crank from a 2.7 he perfers to use. Has not given me a price yet.
Chris
73 911 E
Old 07-08-2013, 09:10 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Contact me by phone or email. We have a large number of over and undersized bearing sets in stock and the price is rarely as bad as urban legend predicts.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 07-08-2013, 03:36 PM
#147 of 2096
Hi,
Talking about urban legends... I have a friend that claims that he uses Toyota fourrunner bearings on 911 engines. But really I do not have any more details. I'm going to call him and ask again. 5vz engines.
Old 07-08-2013, 06:33 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Anything is possible.
Parts are parts...size is all that matters.
I found a set of points one time that fit a Massey Ferguson tractor....and used them in my MG....same size...same screw holes.
Don't be afraid to look into alternate sources.
Check the dimensions of the part you need...and find a transposition catalogue (used to be a staple item at auto wreckers).
Perhaps you will be the one to crack the money/part cost problem we all have!
Bob
Bob Hutson
Old 07-08-2013, 11:44 PM
Straight shooter
Lapkritis's Avatar
Originally Posted by lrodri64 View Post
Hi,
I wouldn't be surprised if there is a cross reference with another engine manufacturer that isn't published. Another $1000 bearing set would never be sold...
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 07-09-2013, 06:47 AM
cmcfaul's Avatar
it's so ridiculous. They are just stamped half circles of metal.
Chris
Old 07-09-2013, 07:41 AM
Chris
... or bi-metal or more. $1000 for a set of bearings would entertain a more viable option of sourcing a std. crank.
Sherwood
Old 07-10-2013, 10:36 AM
cmcfaul's Avatar
Sherwood,
That's the path I am going down. Strange how a 30 lb crank can cost less than .25 lb's of simple curved metal.
My machine shop has a crank from a 2.7 that is standard for $500. Anyone want a perfeclty good one over crank ;-)
I am assuming the 2.7 crank is exactly the same as my 2.4
Chris
73 911 E
Old 07-10-2013, 11:43 AM
Sherwood,
Chris
73 911 E
They made more crankshafts than oversize bearings. Thank God (or equiv. deity) for that stroke of corporate strategy. Imagine sourcing a 1973 Ferrari crank.
Yup. 70.4mm stroke.
Old 07-10-2013, 01:08 PM
