Initial adjustment of mechanical cam tensioner
I am doing a top end refresh on a 2.2 liter and it had mechanical tensioners in it. I want to put them back in, but need some help on setting up the initial tension. I am aware of the draw backs of the mechanical tensioners. The reason I decided to stay with the mechanical tensioners is because of the intended use of the car, it will be a low mile car, only driven about 5000 miles a year. I don't know how many miles were on the engine, it ran well (just leaked oil like crazy) The chains and sprockets were in good shape, no unusual wear marks. So who can give me some advice on how to set the tension? Thanks in advance. (please no lectures on using the adjusters)
With the mechanicals, you decide how tight you want it because once youre running it will be looser than you set it. Thats why the hydraulics work.
Bruce |
Henry posted this some while ago and I have not seen anything better since. |
Thanks Chris, I think I saw this post earlier, and will probably go with that. I just figured porsche mechanics being as anal as they are, and since they run these in race engines, that someone would have a by the numbers precision adjustment technique.
Max Sluiter
Are you sure the factory used to use these in race engines?
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
