Registered Loser
How difficult was your Top end rebuild, I'm thinking about diving in. Newbie as well.
Current Rides:: 1987 Red 911 Targa, 2007 R320 CDI, 2003 Red Dodge Ram Hemi, 1993 Beater Jeep Cherokee, Airbus A320
Gone but not forgotten: 1981 VW Scirocco S, 1989 Honda Accord Coupe LXI, F-16C (still my favorite vehicle!),MC-130P, C-130E, T-38, T-37, C150, C172, PA180
Old 06-08-2011, 04:57 PM
spence88mph's Avatar
Me too, the only fear I have is valve and cam timing, the rest seems pretty straight forward.
'89 911 M491+Turbo
'90 964 C2
'89 944 Turbo
'88 928S4
Old 06-08-2011, 05:01 PM
Hi guys,
If you have some mechanic experience, top end rebuild is not that difficult. all you need is the right tools and good machine shop. I have the lift so it makes my life easy, I have bought the engine stand, some Allen wrenches ( long for exhaust nuts), seals pressing tools, cam tool, "z" holder, some short swivel sockets etc.
After engine removal i had a lot of cleaning, my engine was leaking oil from the thermostat, you can imagine, everything was cover in oil and dirt, lots of hours of cleaning. Be patient when removing exhaust nuts, soak them good in penetrating fluid, if that don't help, heat... Make sure you photograph every step, this will make your life easy later, pay attention to details. I had my heads redone by machine shop in Jersey, very nice guys. They bead clean them, shave valves, seats, supply and pressed new guides, when i got them back, they where ready to install. My advice is to get Wayne's book "How to rebuild and modify Porsche 911 engine", you will get idea how to get the job done. As far of cam timing i was afraid too but when you start doing and understand the process is actually pretty easy, if you will not understand from the book how is done, search the web, forums on Pelican will help or there are some good videos on you tube explaining how the cam timing is done. get all the gaskets and seals in advance so you don't get stuck for a few days, ask me how i know... well, good luck !!! you can do it !!!
Arek
Old 06-08-2011, 07:15 PM
