beancounter
jwasbury's Avatar
Deck height measurement with chamfered heads
Doing a top-end rebuild on a modified turbo engine here and realized that the heads have been chamfered (pic attached). The depth of the chamfer is 40 thou/1mm. Now I am curious about how this may change how I approach deck height. According to the good book, I can measure deck from the top of the cylinder down to the edge of the piston crown. However, given the chamfer, I could theoretically have the edge of the piston crown flush with the cylinder top ("zero deck") and still have 1mm clearance between the crown and the head. So is it correct to add the chamfer depth to the deck measurement to calculate total deck height in this instance?
Any insight is appreciated.
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 06-19-2011, 03:23 PM
PFM PFM is offline
PFM
PFM's Avatar
Jacob,
No pro here but.... If this turbo has flat top pistons and the cut in the head is the first thing the piston can contact then yes it will add to the deck clearance. This could have been done to work on compression too but that is not what you asked.
Stay Tuned,
PFM
Old 06-19-2011, 04:56 PM
beancounter
jwasbury's Avatar
Pistons are not flat topped, but have a small dome to achieve 8/1 compression ratio. The domed portion begins a few millimeter from the edge of the piston, so there is a flat area around the edge. For sure the cut in the head is the first thing the piston can contact. I noted when we tore the engine down that no cylinder base shims were used so it does appear that the original builder was trying to do something with the comp ratio.
Logic certainly suggests that the chamfer should be added to the deck, but I wanted to confirm. I appreciate your response.
Jacob
Old 06-19-2011, 07:23 PM
The piston is only going to come closer to the valve if the recessed part of the head is what makes contact with the cylinder. If the cylinder is going to contact the head on the wider outer part, I don't see how the piston will come any closer.
Wouldn't the chamfer reduce the compression ratio?
Gone
92 C2
82 Euro SC race car
993 C4S 3.8
84 Euro Carrera
Old 06-19-2011, 08:14 PM
BURN-BROS's Avatar
That does not look chamfered. It looks like clearance to run the piston at zero deck to help increase compression.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 06-19-2011, 08:34 PM
Maybe you can check your deck height from the top of the cylinder to the edge of the piston and add the 1mm clearance that is machined into the head.
Just a thought but maybe somebody machined the head instead of getting the correct thickness gaskets.
Old 06-19-2011, 09:32 PM
OldTee's Avatar
There is an instruction in the Wayne's overhaul manual on using clay to check deck height. I suggest you do this test for all cylinders. Up side is you know. Down side is what the hell do you do with all the clay after.
Old Tee
all 911s sold
Old 06-20-2011, 04:16 AM
beancounter
jwasbury's Avatar
Bingo! This is what my thoughts were about the purpose of the head machining. I guess chamfer is the wrong term?
is the recommendation then that we size the base shims to achieve. Zero deck? This would leave 1mm clearance to the head and by my calcs get us to 8/1 comp ratio. Naturally we will verify valve piston clearances.
Old 06-20-2011, 04:35 AM
Grady Clay's Avatar
When you have a flat ‘squish area’ and a dome, there are some unique issues to consider.
Here are a few threads:
Pelican Parts Technical BBS - Search Results
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 06-20-2011, 06:21 AM
PFM PFM is offline
PFM
PFM's Avatar
Grady,
Not much dome on a turbo piston. The outside diameter is darn near flat on the turbo pistons so I do not think it will have much of an affect.
Aaron,
I am not sure how this zero deck setup would give any more compression than setting a 1 mm deck with a space under the cylinder. If the bore of the step in the head matches the cylinder bore anyway.
Stay Tuned,
PFM
Old 06-21-2011, 08:41 PM
BURN-BROS's Avatar
Aaron,
The combustion chamber volume has been reduced by (pi r squared) x 1mm. It is not the same as running a 1mm deck. The piston is closer to the chamber by 1mm which is a significant change.
Burnham Performance
Old 06-22-2011, 07:02 AM
PFM PFM is offline
PFM
PFM's Avatar
Aaron,
Not wanting to sound ignorant here but if metal was removed from the combustion chamber the chamber volume is larger, larger chamber same deck same bore same stroke is lower compression. If the cut stopped at the same diameter as the cylinder how do you figure compression is increased? If the deck height is set to 1 mm via cylinder shims and the chamber is smaller (no cut) the stroke does not change my mind sees a higher compression with cylinder shims. Both assume the cylinder sealing surface is not touched.
Stay Tuned,
PFM
Old 06-22-2011, 07:49 PM
BURN-BROS's Avatar
Aaron,
The amount of material that was removed is very small but the area that the piston now displaces is appreciable. Keep in mind, the heads are now 1mm closer to the piston than it would be with a 1mm shim. The amount of material that was removed is approx .597cc's but the overall chamber volume is reduced approx 6.795cc's bumping compression.
Burnham Performance
Old 06-23-2011, 08:17 AM
PFM PFM is offline
PFM
PFM's Avatar
Aaron,
Thanks that works for me now. Just could not quite get there. The info you provided did the trick.
Thanks,
Stay Tuned,
PFM
Old 06-23-2011, 10:51 AM
BURN-BROS's Avatar
No worries,
That one is hard to visualize.
Burnham Performance
Old 06-23-2011, 05:40 PM
