txhokie4life's Avatar
Pull dist out of 964
I'm going to EFI with my 964 engine and I want to pull the disty and rotor
assembly.
I've removed the single bolt that holds it as well as the allen bolt between
the pair --
but the disty will not budge. Wayne's book just says to remove the one
bolt and it pulls right out. ---
I've had the crank at different points of rotation -- and tried with no luck
but at the moment I've got the flywheel locked and one set of heads off.
any ideas?
thanks,
Mike
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo
2001 996 GT2
1999 Spec Boxster, 1996 993 Cabriolet
1992 964 Cabirolet, 1975 911 RSR Replica Race Car
Old 07-10-2011, 07:57 AM
ALEX P
ALEX P's Avatar
Hi Mike,
There is an o-ring that seals it but the only physical retraint is that single nut.
Have you tried giving it a gentle lever?
Be careful though as others have damaged the dizzy casing if getting too physical with it and they're mega $$$
Old 07-11-2011, 01:59 AM
proffighter's Avatar
Had the same issue when removed mine on my 930. Gentle hits with a rubber hammer up-wards and some WD-40 down the hole helped me. Not a lot of room there I know
Roland
930 Turbo '81 Too many modifications to list
Old 07-11-2011, 04:02 AM
Hadn't been that brave yet :-)
I'll give it a little more persuasion the next time I'm out at the shop working on the engine.
Mike
2001 996 GT2
Old 07-11-2011, 06:13 AM
