Will not start!
Trying to get my freshly rebuilt 85 carrera started.
Checked plug leads and spark, fuel pump and fuel pressure, throttle sensor switch.
I get the occasional back fire, but that's all.
Any one got any ideas?
Old 08-14-2011, 08:17 AM
pete3799's Avatar
Distributor clocked correctly?
Plug wires in proper order?
Pete
79 911SC RoW
Old 08-14-2011, 08:35 AM
Check flywheel sensor, switch them around. The flywheel sensors are the same but send different info.
Bruce
Old 08-14-2011, 12:28 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Bruce
Nice call Bruce, my guess as well.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 08-14-2011, 02:28 PM
Checked the cam timing and plug leads several times.
Replaced the fuel pump in desperation.
Switched the flywheel sensors around and it sounds worse.
Replaced the throttle position switch.
I can only hear one injector ticking, so have just pulled them all and sent them to be checked.
I'm going away for a week tomorrow so I will have to wait to see if this works.
Thankyou for the advice so far.
Lee.
Old 08-15-2011, 09:30 AM
How long was your engine apart?
It is not uncommon for injectors to stick closed after sitting for a few months.
You can stimulate them with a short 12 volt burst from a secondary source.
One more thought: The ground cluster on the left side of the manifold is easily overlooked. Just a thought
Henry Schmidt
Ph: 760-728-3062
Old 08-15-2011, 04:33 PM
