930 Turbo S engine
I am having my engine rebuilt and the mechanic said its a 930 Turbo S engine which according to him he has not seen many of. they have a had a bit of delay getting parts as some of the parts are from a 935. just seeing if any of you guys know anyhting about this engine and the good bad or anything?
84 930 Slant 15 Sonata 2.0T 08 Ram 1500 15 Ram Eco Diesel |
I'm not very familiar with the differences between a 930 and 930S engine but definitely do your research before agreeing to a bill. I can't imagine there are many, if any, 935 specific parts in that motor. There really wasn't much in the way of an increase in HP over the standard 930 if i recall.
Rob Montgomery '88 Blk/Blk 930 ('Lucy') - Not Stock & Not Running |
Max Sluiter
For a race motor, the 935 engine was pretty close to a 930 engine, so it all depends on how you look at the parts- the 935 and 936 used a production crankshaft and case, for example.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Manassas, VA
What is the engine model number? I would look for M30/69S, but I'm not sure.
Pictures would be nice but many of the go-fast parts are probably on the inside. Mark
1991 964 Polar Silver Metallic Turbo Coupe |
its a 930/66 there are quite a few pics of my engine on my thread... had the engine and tranny dropped
I would put a link to the thread if i knew how. its on the 930 turbo page the serial numbers are in some of the pics.
Which doesn't mean that your car isn't a 930S. If I understand correctly, all of these pre-1987 were Special Wishes cars built in Werk 1, and most were slants (flachbau). There's a good thread covering engine options - and most other aspects of the 930S/930SE models - on the 930 forum Slantnose, Slant nose,Slope, M505 factory 930S documents, registry, ultimate,flachbau. But I also believed that the 930S came with better cams (SC?), and a K27 instead of the 3DLZ - which would account for the 330HP I seem to recall was quoted for these - an otherwise stock 930 with SC cams should make that. Which isn't to say that Sonderwunschen couldn't/wouldn't build in more power if ordered. Seem to recall reading they built one German customer a 400HP car - which was more powerful than legally permitted for street use at that time...
'77 S with '78 930 power and a few other things. |
yeah it has the k27, not sure on the cams
