-   -   964 3.3 Turbo EFI Conversion using Syvecs (Life Racing) Engine Management (http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html)
Spenny_b 04-25-2016 11:25 AM
Originally Posted by WERK I (Post 9093299)
Or, you may have an air leak between the suction end of the turbo sump pump and the turbo sump tank.
Hmm, possible. With further inspection I can see a slight oil weep coming from the aux pump area or possibly the rear cam seal in the air pump housing. It's very little, not even dripping, but maybe that -10AN fitting (a banjo using rubber lined sealing washers) is indeed something to investigate further?
Whichever way, it's getting dismantled before everything else goes back together. Tomorrow I'm hoping to pop into Think Auto and collect this weeks shopping list of plumbing items. I'm going to change that -10 from ally to steel I thing, so I can crank down a little harder without fear of shearing the fitting.
Ken911 04-25-2016 12:48 PM
every single time I've had oil anywhere in the intake it's been broken rings
Spenny_b 04-25-2016 02:04 PM
Oh t'riffic.
But...this is the first time I've seen oil puddled there; the intake pipe that feeds into the turbo has been out a few times and there's been no oil, it's also had a full week of running in the dyno cell. How likely is it that a ring would go now? (genuine question, not being contrary)
The cold compression numbers I did before Xmas were all very similar to each other (with the slight exception of one, when the battery was on it's last legs whilst spinning over then engine)
Not re-run a leakdown test since building the engine.
Ken911 04-26-2016 10:38 AM
hopefully they aren't broken. I just haven't been that lucky.
Spenny_b 05-13-2016 03:43 PM
Time for an update....
Many conversations and emails back and forth, and as always, I'm extremely grateful for having guys like Chris, Steve and Craig in "my corner", with sane, sage advice at the ready.
I borrowed a proper leakdown tester from Steve and Craig, a pukka Mac Tools item which is a known good unit (you may remember, I had a cheap and cheerful one that broke first time out, then borrowed another unit which was suspicious due to the gauge not zero'ing)
When hooked up with 100psi applied, each piston @ TDC of the compression stroke, I got the results I didn't want to see.
#1 = 11%
#2 = 2%
#3 = 3%
#4 = 18-19%
#5 = 2%
#6 = 6%
With the headers removed, I have the luxury of being able to feel for any air leaking through the exhaust valves on #1 and #4...very little. Also no immediate sign in the intake plenum....however....I can hear oil bubbling as well as a heavy exhausting or air through the main oil tank breather hose. So, that's pretty conclusive.
Time to stripdown and rebuild.
What's unclear at the moment is both the root cause and the condition of the cylinders.
It could be broken rings, but maybe also "just" a case of the rings not bedding in correctly.
During the running-in period on the dyno, we've been told that the manometer on the crankcase breather was reading well, no sign of blow-by. However, during the last day we did have electrical issues with 4 missing sparks on the 4-6 bank - perhaps this resulted in bore wash?
Det was constantly being monitored by Dave and his headset, none present (or more accurately, during the pulls, any hint of det meant we stopped and adjusted accordingly, as you do when tuning). I've also been told by another specialist, that with air-cooled engines, det is so noticeable ("sounding like a bag of spanners") that you can't miss it. I certainly havent heard any det when driving.
Overall, the engine still sounded good; even, smooth...all the usual signs, so that leads us to believe that we're maybe not looking at broken rings...maybe...who knows, this is just speculation until it's stripped.
Blow-by does also explain why the oil is looking so black and absolutely stinks of fuel/exhaust, although not necessarily why oil is sitting in the turbo intake - that appears to have been sucked up from the oil drip tank on the turbo. Why there was even oil in there, is another thing altogether, it should surely be pretty much empty all the time (less oil being fed into the GT35 than the K27, but the same capacity pump scavenging it)…is the aux pump knackered? It’ll all be checked.
Using a cheap (but not-so-cheerful) borescope, the pics I’ve got of the cylinder bores aren’t the best - limited focal length on this scope - again, best just to inspect once stripped, but I have a feeling that they’ll need redoing with Nikasil coating, if what we’re seeing is correct.
Currently, with being extremely busy at work, I've not made a lot of progress for the last week in terms of getting the drivetrain removed…too many late evening returns, feeling like groundhog day (in fact, the works Nissan slogan of “Eat Sleep Race Repeat” is apt…more like ”Eat Sleep Work Repeat”). All good fun, but not good for getting off the sofa in the evening.
The top side of the engine is disconnected with the exception of the fuel lines. The headers are still off, bumper removed, heat shields out. Need to drain the oil, remove the oil lines and everything else (clutch slave, power cables, transmission linkage, driveshafts, etc). I’m collecting the engine hoist and engine stand tomorrow morning; really hoping to have something to dismantle by end of play.
WERK I 05-14-2016 04:28 AM
^^^^ Man, that just sucks....
Sorry to hear of your blow-by issue. If there are broken rings, detonation may not be the culprit. Rings gaps too tight or ring land excessive play can quickly ruin rings. After following your build and seeing how absolutely thorough you've been, this is one for the books.
Were these cylinders replated? I could see a plating failure cause this problem.
Are you filtering the return oil from the turbocharger?
Spenny_b 05-14-2016 04:50 AM
Cheers mate, yeah, does kinda suck...
...BUT....
....there may be a silver lining to this cloud ;) [cue dramatic music and a dastardly "muh-hah-hah"]
No, the cylinders were brand new 98mm LN Nickies with fire-rings channels machined into the top, so I can run Ni-Resist rings between cylinder and head.
Yes, in fact the very last mod I did before we went to the dyno was to plumb-in a -8AN Mocal inline filter between the drip tank and the aux pump.
Oil drained, lines removed, WG's off, time for a cheese toastie and a cuppa, then driveshafts, throttle linkage, fuel lines.
I've retrieved the engine crane and the engine stand - no excuses now for not getting the lump out today.
WERK I 05-14-2016 05:52 AM
"Yes, in fact the very last mod I did before we went to the dyno was to plumb-in a -8AN Mocal inline filter between the drip tank and the aux pump."
I always thought that a filtration system is more effective when it is plumbed on the pressure side of a pump, no?
Spenny_b 05-14-2016 06:04 AM
I don't know? Maybe that's the case and would then explain why I'm not seeing as much scavenging happening from the drip tank as I would expect?
I haven't got the finest filtration element in the filter, and my thinking was that putting it here would also then protect the pump from any detritus in the inbound oil.
It's easily removed, although plumbing it back into the exit side would require some -8 fittings to be swaged onto the existing rubber hose (not impossible by any stretch, just a job that needs to be remembered)
Brainz 05-14-2016 07:44 AM
I don't have a 930, but have 997 with aftermarket turbo. I had issues with a smoking turbo which I tracked down to two issues: 1) inadequate crankcase vacuum, and (maybe) 2) smallish turbo drain line. I fixed the AOS/PCV system first, which increased crankcase vaccum and not only helped pull the oil through the drainline (and hence eliminate the smoking), but also appears to have helped with blowby. Not sure if it's true, or why, but I've read that rings like a bit of crankcase vacuum to help with sealing. Also, in researching the smoking issue, on many turbo forums (not necessarily Porsche) the consensus was to have the biggest drain line/lowest restriction possible. -10 and -12 were often recommended. I switched to a -10 drain which is ~2x the cross section I had previously and it seems to work much better. Again, not a 930 expert, but I wouldn't think you'd want a filter or any other restrictions on the drain side.
Sent from my Nexus 6 using Tapatalk
boosted79 05-14-2016 08:12 AM
" Not sure if it's true, or why, but I've read that rings like a bit of crankcase vacuum to help with sealing."
Absolutely true. Early systems ran the breathers into the header collectors which helped evacuate the case to both reduce windage losses and improve ring seal. Belt driven vac pumps are now used to pull a vac on the case.
Spenny_b 05-14-2016 10:31 AM
Originally Posted by Brainz (Post 9120326)
....Also, in researching the smoking issue, on many turbo forums (not necessarily Porsche) the consensus was to have the biggest drain line/lowest restriction possible. -10 and -12 were often recommended. I switched to a -10 drain which is ~2x the cross section I had previously and it seems to work much better. Again, not a 930 expert, but I wouldn't think you'd want a filter or any other restrictions on the drain side.
Hi Brainz,
Sorry, my previous description perhaps wasn't the clearest; the turbo drain line I'm using is indeed a -10AN run, about 10" long, which runs from the turbo housing to the turbo drain (drip) tank. This tank has the capacity to hold perhaps just under a litre of oil, and has 2 further connections, both -8AN.
1) The first is a breather line, that runs back up to the air intake pipe. This line is about 2ft long with maybe 1-1.5ft of height difference (and is providing the path that the oil appears to have taken back into the turbo compressor intake)
2) The second -8 line is the one used by the auxiliary pump to pull the drained oil back from the drain tank to the main oil tank in the RH wing. Although it's a new line I've made, the original rigid line was of the same ID (but I'm unable to use it, as the turbo drain tank is one that I've fabricated, sits in a slightly different orientation and has different fittings). It follows the same path, so approx the same length but the only functional difference is that I have that inline oil filter midway along its length (which as WERK I suggested above, may not be ideal for suction strength).
Re crankcase vacuum, yup, in fact when I converted a previous engine (GM Vauxhall 2.0 XE "Red Top") from wet sump to dry sump, the dry sump pump was mounted externally to the engine and was belt driven off the crank pulley, and did indeed generate a significant vaccum, which had a secondary effect of adding a few hp. I expect that the internally mounted dry sump pump of the aircooled lumps to have the same effect w.r.t. vacuum.
Brainz 05-14-2016 11:00 AM
Thanks for the explanations, guys. I had not considered that the dry sump helps with the crankcase vacuum. I hope you get things sorted without any lengthy or expensive issues.
boosted79 05-14-2016 12:00 PM
That really s^&%$. After all of that work. It's unlikely that two bores would not seat when the others are fine? Was a leakdown done after assembly but before run in? That's a good thing to do just to give a base line.
Spenny_b 05-14-2016 01:37 PM
Yup, indeed I did. It was after I assembled the heads and had to re-lap the valves in (long story involving a supposedly reputed engine builder here in the UK...utter twat).
What I would say, is that I didn't use the same leakdown tester that I used last week (the Mac Tools one), it was a bit of a home built tester that used both spark plug holes (measured pressure of air in one, read %-age loss via the other). Although not 100% confident of the absolute numbers I got, they were at least consistent across all 6, at around 2-3% iirc.
Fear not guys, there WILL be a happy ending here....Karma will make it right, lol!
304065 05-17-2016 06:10 AM
. . . sigh. . .unlucky, just unlucky, as they used to say about my batting at Cricket.
You are getting good at engine R&R. . . I finally fixed my flywheel seal after FOUR engine drops. . . documented here: Assembling 901/05 Engine- Phase VII-- ANOTHER flywheel seal change!
It just takes TIME, which seems to be perpetually in short supply. . . persevere, and you will triumph!
At least having the jugs off will afford you the opportunity to check out the cylinder base sealing as well. It's interesting what you find when you do things over. . . what took hours of contemplation before and eight checks of the workshop manual now comes easily. Do you think you can remove the heads in banks of three so you don't have to pull the valvetrain apart?
Spenny_b 05-17-2016 04:26 PM
Hi John,
Yep, completely soul destroying to tear down something that a) took a long time to build in the first place, and b) now looks dirty again and needs re-cleaning (cosmetically rather than internally).
Lol @ your cricket! No comment!
Funnily enough, the leak I was seeing (which I thought was) coming from #5 cylinder base was I think, actually oil running down from the top side, due to the earlier hose popping from the chimney...which it now turns out was down to excessive crankcase pressure...which is probably also why I was seeing a few weeps here-and-there that didn't exist when we ran it on the dyno (and we were checking very thoroughly with a torch for any signs of leaks, for obvious reasons). A number of "things" now adding up.
Yup, that's the plan, and hopefully may not have to strip the bottom end after checking stuff out.
Spenny_b 05-17-2016 04:38 PM
Progress update....
Finally got the engine and trans removed by midday on Sunday (some car storage logistics got in the way on Sat). As John mentioned, getting a little quicker at this now, but not a job I want any more practice doing...
http://img.photobucket.com/albums/v2...6595B30308.jpg
Build-up the engine stand (it's a heavy bugger!), get the engine mounted, and it's teardown time.
Sorry Sir, I didn't quite catch that, "A complete EFI system, ready to go" you say? Well, yes indeed, it is.... Sorry, not for sale....
http://img.photobucket.com/albums/v2...53FB0C297F.jpg
The usual stripdown pics....
http://img.photobucket.com/albums/v2...2ABF01C297.jpg
http://img.photobucket.com/albums/v2...D96ED9E768.jpg
And this is where we're at as-of midnight this evening...
http://img.photobucket.com/albums/v2...0B95435BA8.jpg
http://img.photobucket.com/albums/v2...7D09FC361A.jpg
Lots of careful bagging and storing. Running out of space, may need to borrow a few wallpapering tables. Hoping to get the top end for each bank off by end of play tomorrow night.
TurboKraft 05-17-2016 10:43 PM
Great job and a positive spirit, sir!
jsveb 05-19-2016 10:58 AM
Spenny, I completely missed this. I am so sorry to learn this. You don't deserve such a situation. You have been so meticulous.
I really hope something great comes out of this.
Spenny_b 05-19-2016 04:36 PM
Cheers matey, yeah, not good but I can take comfort in what I've discovered this evening....
Spenny_b 05-19-2016 05:06 PM
D-Day (Discovery Day)
Ok, so I deliberately left things at a convenient place last night; the heads for 4-5-6 were off (still attached to the cam carrier) and I could see pretty much the full stroke of #4 bore, but decided to leave the cylinder removal until today.
BTW, using an engine crane to lift the cam carrier+heads assembly makes life a lot easier; the oil return tubes really grab the carrier casting, gently lifting it using the crane is a lot easier and less brutal than trying to heave it off. Just in case a newb is reading.
#5 cylinder was first to be removed, and it kind of set the tone for the other two on that bank....completely mullered rings....
#4 = all 3 rings smashed to pieces
#5 = top ring snapped in two places, and oil control ring smashed to pieces
#6 = top ring snapped
(for reference, the leak downs were #4=19%, #5=2%, #6=6%)
Thankfully, all 3 cylinders on this bank look to be good, no evidence of scoring and the integrity of the Nikasil plating looks fine. I'm not getting my hopes up just yet, they need to be measured before I'm happy.
Next, time to strip the 1-2-3 bank down and repeat the process. Better news...
#1 = Broken top ring (in 2 places), oil control ring not as badly damaged as #4, but still has chunks missing in 3 places
#2 = All rings are fine
#3 = All rings are fine
So, during the break between stripping each bank, Steve and I were chatting about what could cause such catastrophic failure of rings on the RH bank - he's never seen something this drastic.
For those who have been following the build for a while, you may remember that whilst on the engine dyno last year (in fact, exactly a year ago), we had a serious set of electrical problems, the most severe being that we lost the lower plugs on 4-5-6, plus the top plug on #6. Wrongly wired pin in one of the amp connections, plus another amp that was intermittent, which fixed itself "magically", and still seems fine now.
The best theory we have at the moment, is that this loss of ignition (and about 140bhp), caused excessive richness, detected by the Lambda but only at a global level across the whole engine. An auto correction was made, possibly causing it to run abnormally lean, and therefore hotter....the excessive unburnt fuel was at the same time washing the bores, removing oil obviously. With the increase in temperature, plus dry cylinders, it's plausible that the rings had massively increased friction, causing them to shatter.
The same cylinders that we had ignition problems with, are the same ones that havve utterly destroyed rings. What it doesn't explain is why #1 is also damaged.
Anyway, some horror shots for you, in no particular order apart from being 4-5-6...
http://img.photobucket.com/albums/v2...090A464EE7.jpg
http://img.photobucket.com/albums/v2...75BA4223EA.jpg
http://img.photobucket.com/albums/v2...79BD174F4D.jpg
http://img.photobucket.com/albums/v2...CF14560C1A.jpg
http://img.photobucket.com/albums/v2...0A464EE7_1.jpg
http://img.photobucket.com/albums/v2...D766677F13.jpg
And some fragments...(this is just #4!)
http://img.photobucket.com/albums/v2...A3CCEDB69F.jpg
Short block and a bench full of parts...
http://img.photobucket.com/albums/v2...91E08710E4.jpg
http://img.photobucket.com/albums/v2...EBBC1EEF48.jpg
And the expensive stuff...
http://img.photobucket.com/albums/v2...F77F360ABE.jpg
Next job is to measure everything, which isn't likely to be this week as I need to get it all up to Steves and use the SBD shop Mitutoyo kit.
Tippy 05-19-2016 06:41 PM
That is seriously nauseating
911 tweaks 05-20-2016 03:13 AM
Spenny_b... I also have been following your build with great interest in doing such a build... after all of this time, effort,grief & expense, keep your chin up...! You are doing a fine job with what can happen when pushing the frontier on anything...!!! This will be conquered... hang in there... The second time is always at least 1/2 the time of the original build... carry on... Best of luck... Bob
Spenny_b 05-20-2016 08:53 AM
Yeah, I confess to feeling like I was going to throw-up a few weeks ago when all the evidence started to make sense. The same sensation you get on receipt of really bad news when your legs go to jelly. I did stop short of hyper-ventilating though, lol!
Thanks for the kind words Bob, for sure, we plough on and see what needs to be done....second time's always a better build anyway, haha!
Costa P 05-20-2016 11:39 AM
Spenny......im at a total loss for words!
Pain.....feeling such pain for you mate.
304065 05-24-2016 06:21 AM
Spencer: while I join the chorus of bemoans for the wasted parts and time, I am very impressed that you had the judgment to correctly diagnose and then immediately attack the problem. And you are rewarded with bits of shattered ring RIGHT where you expected.
Observation: A no-spark, fuel present condition shows as a LEAN condition to a wideband AF meter. The O2 sensor works by comparing the difference between the % oxygen in free air to the % oxygen measured in the exhaust gas. When the mixture is rich, the combustion event has consumed more O2 than stoch, hence there is less O2 in the exhaust. When it's lean, less O2 has reacted, so there is more present in the exhaust. If you lose the plugs then you end up with even MORE O2 in the mix, hence it shows as lean.
My money is on the ignition malfunction firing way early resulting in classic detonation. I don't see any erosion of the ring lands in your photos, but I'm looking at them on my mobile.
You are on the right track to mic everything up and that will make your next step perfectly clear.
Persevere! She shall howl again soon.
Tippy 05-24-2016 07:14 AM
Best wishes and speedy recovery!
I like the explanation above, makes sense as a possibility.
fredT 05-24-2016 07:18 AM
Sucky luck Spencer :(
I'm sure you will get it right, but this is gutting to hear nevertheless.
Makes me think I personally did the right thing with my shortcut to hotrodding, as as a checkbook mechanic this sort of stuff would would have cleaned out my wallet as well as my soul!
Hoping you'll get good wind and plain sailing going forward!
Spenny_b 05-24-2016 01:43 PM
Thanks for all your well-wishes guys, appreciated ;)
Originally Posted by 304065 (Post 9133059)
...My money is on the ignition malfunction firing way early resulting in classic detonation. I don't see any erosion of the ring lands in your photos, but I'm looking at them on my mobile.
Hmm, I'm not so sure...Dave the dyno operator was wearing the det-cans on every run that was made right up to the final run on the Friday evening (I seem to remember posting a photo of said Dave wearing said headphones!).
From what I understand, if we did have det, it would *likely* only shatter the top ring, it'd have to be monstrous to destroy the 2nd ring, but to bust all three? Steve's never known that, and I'm pretty sure from speaking with Chris, that he hasn't either (stand to be corrected though)....you'd also expect to see evidence of det on all 6 cylinders, but 2&3 are fine.
Was hoping to do this at lunch but stars didnt quite align - instead I've borrowed Steve/Craigs bore gauges and digi micrometer. Frankly I feel like death-warmed-up this evening, so it'll have to wait a few nights.
The planned way forward, before I disturb anything in terms of cleaning, is for me to try and book a days vacation and get up to Birmingham and speak directly with Fred @ Omega, see what his diagnosis is by examining the tell-tale markings (and see if he'll measure them on his rig, as I don't yet know the measuring points on these pistons, nor the original drawing dimensions)
Yeah, hoping. Fecking car. :rolleyes:
911 tweaks 05-24-2016 03:42 PM
May I suggest as I bet you are going to do is examine the assembly tools used to get the pistons into the jugs AND to double check all of the measurements = jug dia and its wanted tolerance to piston & rings... I am leaning twds the rings getting damaged during piston/rings install and/or inaccurate tolerance btwn jug and piston & rings... The head phones would of clearly herd any pinging/knocking if it was happening... jmho... Also, depending on what compression you are running, now is the time to possibly alter that while the engine is apart...
boosted79 05-24-2016 05:02 PM
Ring end gaps?
Raceboy 05-24-2016 10:13 PM
If rings are broken, it is 99% sign of a detonation. If pistons are not melted, it means that detonation has not caused pre-ignition yet.
Ken911 05-25-2016 08:17 AM
Since you had detonation make sure the tops of the cyclinders are still round. Mine were not. When i sent them for replating i was told they were no longer round and should be replaced or cryo treated before they could be rebored and replated. I couldnt afford new ones so i had them cryotreated before they were rebored and replated.
Spenny_b 07-06-2016 04:50 PM
Time for an update
A trip up to see the 2 guys who own Omega in Halesowen (near Birmingham in the Midlands) was interesting, if not entirely successful in 100% diagnosis. This was over a month ago now, so bear with me while I try and remember the minutiae of the hour or so I spent there.
Long story short, this has stumped them both….I’ve stumped two guys who must be considered some of the leading authorities on piston design. Fantastic, if you’re going to do something, then *really* do it…
So, they can’t tell me the absolute root cause for the shattered rings. What they can tell me, categorically, are a few things that have NOT been the root cause….which you have to say, is almost as useful.
1 - First off, it’s definitely not detonation. No evidence of det on the piston edges, nor any deposits on the pistons that would usually accompany pre-det.
2 - Secondly, a theory that perhaps it could be related to some missing sparks whilst on the dyno (and perhaps bore wash) is also not the cause.
3 - Thirdly, there's no evidence of fretting on the ring ends, not even point contact, so incorrect ring gaps are extremely unlikely (especially since 2 cylinders are perfectly ok; that would have to be one helluva an unlikely tolerance stack-up to not see the problem on 2 of 6)
Other observations are:
1) That they don’t know exactly which rings these are….crazy as it sounds, they have the appearance of a steel ring but have the rigidity of a cast iron ring. The rings were supplied to me in a JE Pistons box (and dammit, I’ve had that empty box in my toolchest for 3yrs, until a few months ago when I had a clear-out). However, the packets with the rings were not sealed, and so they could’ve been any hokey old ring set, and knowing the outfit who supplied them, this is entirely plausible.
2) The chamfer on the inside edge of the compression rings is way bigger than they would ever spec, meaning it’s flexing significantly, perhaps excessively (for those who don’t know, this chamfer is used to allow the rings to behave a little like a window squeegie, exerting pressure onto the cylinder wall with piston motion)
3) The oil control ring should be flexible; Fred cited that their oil rings can literally be un-curled without snapping. At this point I start having 1980’s flashbacks and the ultra flexible material they made spectacles out of! When we got hold of one of my oil rings, it broke like a dry biscuit - very little elasticity, FAR too brittle.
4) There is a decent amount of scuffing on the piston skirts. More on the pistons with broken rings.
(As an aside, it’s at this point that Fred and Benk explain the intricacies of piston design, with not only a tapering of the skirt, but also an asymmetrical barreling between the bottom ring land and the bottom of the piston, in addition to the oval nature (in plan view) of the skirt. Some very big radii, think approx 1m in places.)
This scuffing has likely been caused by the lack of control of the piston in the upward stroke, by virtue of the rings being destroyed, causing excessive rocking. Still usable, but….
…when Chris and I then had a very long chat over FaceTime shortly afterwards, it appears that the diameter of the skirt is smaller than a brand new 98mm CP Carillo item that Chris had to hand in the shop. This starts to add up….the set of pistons I bought were the last of a batch run commissioned by [he who I’ll not name again] ….the old knackered pistons that [said person] tried to offload onto me were out of his 935 replica endurance race car….so, chances are, these pistons were of the same batch intended to spend many hours at WOT and running massive boost….and heat. Not a good candidate for a road piston, of course.
Which is disappointing.
So, the first item on the shopping list is a set of CP Carillo pistons. Chris and I have discussed at length, the ball is in my court to obtain some dimensions and send them over, so that a set of designs can be finalised which maintain the same compression ratio as we’ve dyno’d and mapped with. The engine is going to need re-dyno’ing again anyway, in order to perform a controlled running-in, but this is likely to only need 2 days dyno time - Day 1 to bolt it to the rig and fire it up, Day 2 to do some mapping, double check and refine. If we go radically altering the CR by more than 0.1:1, it’s really a case of all-bets-off and start again. No thanks.
The next thing to check were the cylinders. Steve & Craig very kindly lent me their Mitutoyo bore gauge set and the relevant digital micrometer….conscious that John is reading ;) …so I made sure that everything was stored in the cooler confines of the garage for a day before measuring, lol!
Each barrel was measured both per the diagrams in Waynes book, but also per the Porsche factory manuals, plus in an area below where the rings travel at the bottom of the spigot. X & Y directions of course, I spent a good couple of hours doing this myself, noting, checking, re-checking, because frankly, I was aghast with some of the dimensions I was seeing. Time to make a journey up to SBD and ask Craig to mark-my-homework. In fact, we repeated the measurements, him measuring, me scribing. Sure enough, give or take the minute differences due to measuring locations, the dimensions were very similar to mine. Bugger. They’re well-worn; in fact, Chris commented that he’s not seen a set of cylinders this worn since stripping a race motor after 5 seasons of hard use. The good news is that they should be fixable.
The plan of action is for me to ship the cylinders back to Chris for him to get them stripped, re-plated and honed to the same spec as they would’ve left LN with originally. The pistons will be ordered, with the relevant rings (this time we'll be using 1mm not 1.5mm per the Omegas, which were designed for JE rings). Chris or Mike will then gap the rings, check everything, and assemble the pistons into the cylinders for a trial fit. New Wrightwood gaskets are going to be used for the re-assembly.
Realistically I’m planning on this all now happening towards the backend of summer, for an autumn rebuild. Feeling more than a little broke at the moment, need to sell some tin to get some commission payments! Mind you, it’s not helped by me having a mad-moment a few weeks ago and buying a new daily driver….F10 LCI generation M5….has to be one of the performance bargains of the moment (in the UK at least), unbelievable amount of car and performance for the money, I’d highly recommend. A complete weapon of a chariot that’s still scaring the crap out of me. Never owned a V8 before, so another box ticked. I’ll chuck up a pic of it at some point - for some reason Photobucket isn’t playing nicely, not allowing me to upload any content.
So that’s where we’re up to….trying to retrieve an errant wrist pin spring that (sods law) managed to ping its way into the crankcase. Have had a couple of attempts to see it (bore scope) and fish for it (magnets of different types), with no success yet. Fingers crossed I don’t end up stripping the bottom end for one bloody clip.
Brainz 07-07-2016 11:01 AM
Very sorry to hear, but sounds like you've got a great plan. As always, thanks much for posting your experience - - very educational. Look forward to hearing your progress later this year.
Side note, I watched the Speed Academy 930 series on YouTube (a couple times, actually) . Chris and the team at TurboKraft are truly top-notch, and nice guys to boot. I've been really impressed with the help they've provided you and others on this forum. So professional. Best wishes.
Spenny_b 07-07-2016 03:16 PM
No worries, and thanks for the encouragement!
I've said it before, along with many others; Chris is an absolute top bloke, and somebody who I very much regard as a friend.
I've only spoken briefly to Mike once, a long time ago, and not spoken with John, but with their diligence and talent, I imagine that they're also great guys to have in the TurboKraft speed-shop.
(I've also watched a number of the Speed Academy videos, very good they are too)
Pat RUFBTR 07-09-2016 05:35 AM
Hello Spencer,
I have unfortunately just discovered your driving problem, I am great disgusted for you, stand firm and especially do not discourage you! We are with you.
Patrice
fredT 12-07-2016 03:08 AM
Hey Spencer how's it going?
What is going on with this?
Cheers
Spenny_b 12-07-2016 03:52 PM
Hey Fred,
Well, we're underway again, have been for some months although most of that time has been spent investigating, planning, cleaning....saving....
The cylinders are now back with LN via Chris at TurboKraft, to be reworked in readiness for a set of CP Carrillo pistons. Chris is going to handle this part once he has the cylinders back.
In parallel, I've been focussing on the ignition system - trying something which I don't believe anyone else has yet experimented with...a real case of "why not, whilst I'm at it". A fair amount of extra work needed, but I'll reveal all, once it's complete.
The 12x Denso (Honda CBR600) pencil coils are going to be up for sale very soon, as-are the 4x 3-channel Bosch amplifier units that drive them....if anyone's interested, then do send me a PM. All immaculate condition as you'd expect after only 3 days actively running on the dyno and 300 road miles afterwards.
The engine half of the wiring loom is back with Simon @ Sileck for reworking, or rather, in anticipation of me giving him the nod that my experimental project is good, then he'll start the rework.
Did have half a thought to also look at swapping in some new cams - again, while I'm at it....but frankly the budget just isn't there, and after discussing with Chris at length, the 964 Carrera cams should still be absolutely fine for what I need.
That's about it really. Will post some pics once there's stuff worth photographing, but yup, it's underway again, thanks for checking in!
Cheers
S
