txhokie4life's Avatar
Can't figure out Intake Gasket part #
Finished my 964 long block.
Ready to put it in my track car.
Going to use the TWM Throttle Bodies.
They have an interposer which converts the 2 bolt oval pattern
to the 3 bolt cylinder heads.
Would love to get a link or a part #
thanks in advance!
Mike
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo
2001 996 GT2
1999 Spec Boxster, 1996 993 Cabriolet
1992 964 Cabirolet, 1975 911 RSR Replica Race Car
Old 09-08-2011, 07:56 AM
Try not, Do or Do not
Henry Schmidt's Avatar
thanks in advance!
Mike
I don't know the part number but I have a nice used set I'd be happy to sell.
These are huge (46'x 54mm) so I assume hey are for racing only.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 09-08-2011, 11:38 AM
gaskets
If you need gaskets for the 3 bolt port call PMO they have them and the large 2 bolt as well
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 09-08-2011, 11:57 AM
Wow, getting old sucks.
I missed the part about the gaskets.
Henry Schmidt
Ph: 760-728-3062
Old 09-08-2011, 01:19 PM
Okay -- took me a bit -- Now I know why I can't find a part.
The 964 engine donor (as opposed to the Throttle Body engine)
had the plastic intake manifold. The plastics seals (maybe with an oring)
to the 3 studs.
I might have to just make some gaskets with some gasket sheet material.
Was hoping to find it locally as I'd like to install the engine this weekend.
thx.
Mike
2001 996 GT2
Old 09-08-2011, 03:39 PM
BoxxerSix's Avatar
yes it's an o-ring on the 964/993 part number 993 110 713 01
Adam Hennessy
Old 09-08-2011, 05:19 PM
Just glue the intake adapter to the head using ThreeBond 1194.
It will seal and is relatively easy to remove later.
Henry Schmidt
Ph: 760-728-3062
Old 09-09-2011, 09:03 AM
