johndaroza's Avatar
Over heating 3.2
I have a rebuilt engine witch a mechanic left out the O rings at the oil pump started the engine lost all oil Pressure at one point so it has been rebuilt 2 times!
Used same barrings.
now the timing light says it is running retarded and lean, the mechanic said it was the chip so bough Steve Wong chip well that did not work like I thought it would not in the first place,
now it is not running lean don't know about the retardation haven't checked it.
but what could it be??
can it be the cam's have been installed wrong? installed at a retared seating?
Would that mess up the computer and may lean it out? cus that what I,m thinking? what elce can it be? any help out there? Please what do I do?
Old 09-07-2011, 08:59 PM
proporsche's Avatar
carrera overheating?
Hello John
Are you using the same mechanic who forgot to put the oil pump o rings?
If yes i would go and ask some other mechanic to check your car.
First does your engine spin easy?With alternator belt of.If yes it is good start. Your timing is set by factory you cannot change it on distributor.
Next i would check the camshaft timing .This is very important.The timing should be 1,1-1,4 the best is 1.3...Have this check first.
proporsche
Old 09-08-2011, 02:36 AM
johndaroza's Avatar
that is were I am heading thanks any others and any more info?
Old 09-08-2011, 06:58 AM
But you can have your distributor off location and still run.
Bruce
Old 09-08-2011, 07:34 AM
proporsche's Avatar
hi bruce
not on 1984-89 Carrera`s there is only one way to put in distributor...otherwise the engine will misfire....not run at all.
proporsche
Old 09-08-2011, 10:08 AM
Max Sluiter
Flieger's Avatar
I would find a better mechanic firstly.
Old 09-08-2011, 11:06 AM
There is 12 different ways to install a distributor, 11 wrong. There is 4 oil pump seals in a bottom end pack. If you have 2 or 3 left over before you do the through bolts, you have to know youre wrong.
Bruce
Old 09-08-2011, 11:43 AM
johndaroza's Avatar
there were no oil seals left in the pack the first time the motor fired first time around I played with these before, But some elce timed the cams this time and that is what I think is wrong with it, the cam timing? never had it before have any one elce?
Old 09-08-2011, 10:15 PM
proporsche's Avatar
Hello John
Can you take it from the beginning?What was the reason you have rebuilt the engine.
Do you know what kind of main bearings you have in?Standart or?IN this condition the engine starts and run just over heats,right?How long does it take to over heat?
let me know if you like in an email..
proporsche@yahoo.com
proporsche
Old 09-09-2011, 12:18 AM
proporsche's Avatar
hello Bruce
it does not matter how many ways is to put in distributor.In John case the car is not misfireing his car is overheating lets focus on that and try to help him.
BTW oil pump takes 3 o rings and 1 is for the case right?
proporsche
Old 09-09-2011, 02:03 AM
johndaroza's Avatar
well thanks for your thoughts!this was just a standerd engine rebuild had 210,000 miles on it. and leaked ran like a raped ape! at this point it is going to be torn apart next week, I,m shure the barrings are fryed as that the only thing left not there not a nock but that is were it has to be at this point well now I have a cance to make it better I,m going to send the crank out to have work done to it some lighting too, I am looking to make it pull like turbo any one have some euro Pistions, can I get a bigger throtol body for the 3.2
Old 09-09-2011, 04:05 PM
proporsche's Avatar
Hi John
I think that is the best way to start from the bottom end:-).
I wish you good luck and if you have any Q in the future you got my mail.
To make it pull like a turbo all you have to do time the cams to 1.3+1/2.get a strait pipe for Catalytic converter and get a chip for your coputer from POWERCHIP in California...
Your Porsche will fly ....
proporche
Old 09-09-2011, 11:08 PM
johndaroza's Avatar
thanks so much
I have new SSI headers Steave wong chip 20/21 webcams light cluch light fly wheel, am going to send the crank out to castillos in LA to have it worked over and knife edged ,
am pulling the oil pump and taking it apart and starting from there.
Any one know were I can get a bigger mass flow air censer?
and any one have any euro P's ands C's for me with low miles? I,m trying make 288hp that should be good!
Well if you can't spend less spend more and more and getting mad is a wast of time,
if you can not laft this off like I will because it just can not get any worse than this just think three times ! and tap you red heals and say you want to go home! HAHAHA Good news to come frome here on out??
Old 09-10-2011, 02:41 PM
