totle's Avatar
broken head studs
I have searched the forum and found several threads about this.
Seems like welding a nut on the stud is a selected choice.
I have tried this method, but the stud is broken all the way down to the case, with only a small bit sticking up.
When welding I was only able to weld on top of the stud, but this was not strong enough.
New bits of stud just came off
Here is what it looks like.
Is the only solution to drill it out?
Have 2 studs like this
The engine is a 79 3.0 SC
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 09-14-2011, 01:17 PM
Studs
If that is the lower stud, and it looks to be and its dilivar, prepare yourself to disassemble the case to have a machine shop set it up on the mill and drill it out, they are hard as glass and you need a solid carbide drill to deal with those, been there and done that many times, I have repaired many that tried to do it freehand and its ugly. I have tig welded nuts to the broken studs and then heated the case to release the loc tite and thats the only thing that may work with that.
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 09-14-2011, 01:43 PM
Tig weld a nut to it if there is room if not sharpen a bolt to some what of a point and tig weld that to it. Put some heat to the case and it should back on out. I have lost count of how many we have done this way.
Old 09-14-2011, 01:52 PM
totle's Avatar
Hi Mike,
Nice to hear from you.
Yes, it is the lower stud, and looks to be dilivar studs.
One lower on one side, and 2 lower studs on the other side.
Will take your advise and disassemble the case then.
Trond R.
1986 944 Turbo
Old 09-14-2011, 02:01 PM
totle's Avatar
Will give TIG weld a try before disassemble the case
Trond R.
1986 944 Turbo
Old 09-14-2011, 02:02 PM
Turbo
How is your turbo project doing, I didn't see that it was you til after I sent the post
Mike Bruns
Old 09-14-2011, 02:38 PM
totle's Avatar
Hi Mike,
My turbo build went fine. Thanks again for your help in sourcing all the parts and ship to me.
After I had the local mechanic gap the piston rings, I assembled the engine and was driving very careful with no boost until I had the car in the Dyno (Dynopack) for fine tune.
We ended up making new fuel and ignition tables rather than starting with the one I had.
After I compared the new and the old tables, I saw that the new fuel table was a bit richer all over, and new ignition table more restrictive.
Ended up with 505 rwhp and 635 rNm torque at 1,1 bar
Engine is running great on both street and track
Trond R.
1986 944 Turbo
Old 09-14-2011, 03:52 PM
Air Medal or two
afterburn 549's Avatar
HEAT is your friend
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 09-14-2011, 05:18 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Strip the engine down to a short block and have the studs removed using EDM
(Electric discharge machining). Try a company that removes broken taps.
If you can manage to keep the case clean inside you're good to go.
I have my doubts about your ability to "keep it clean" but it's worth a try.
If at that point you choose to take it apart, the studs are already removed.
Good luck
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 09-15-2011, 12:55 AM
