MBruns for President
JeremyD's Avatar
Will a 993 SS cam - originally for a 3.2
Fit a 964 cam carrier on a 964 3.6? I have the PS pump blocked off. Sure looks like the cam nut is the same.
Old 11-15-2011, 07:40 PM
I dont quite understand the question other than all 3.2, 964, and 993 lock with the same bolt and heavy washer.
Bruce
Old 11-16-2011, 06:36 PM
JeremyD's Avatar
As in - is the cam carrier the same for a 964 as it is for a 3.2 Carrera?
a set of cams were made for a 3.2 carrera - these cams were made with a (993SS grind)
These cams came up for sale with very little hours in good shape by someone I trust.
I would like to know if these will fit a 964 engine that I have...
Old 11-16-2011, 07:16 PM
Yes, they will, all the cam carriers for Carrera and 964 are basically the same, inside, as the cams are the same.
Bruce
Old 11-16-2011, 07:43 PM
JeremyD's Avatar
Thanks Bruce - that's what I thought - but wanted confirmation
Old 11-16-2011, 07:59 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Another angle to this is the stock 964 cam is commonly installed/upgraded to Carreras or SCs by grinding off the PS pump drive. So that tells you the 964 cam fits the older cam towers and therefore a Carrera or SC cam will drop into the 3.6 tower.
Kevin L
'86 Carrera "Larry"
Old 11-17-2011, 02:30 PM
JeremyD's Avatar
Yeah, I knew that side - was pretty sure - just wanted another opinion...
Old 11-17-2011, 02:44 PM
Jeff Alton's Avatar
Some 89 3.2 motors have cam carriers with 964 part numbers on them as well.
Good luck with your build/repair Jeremy.
Cheers
www.turn3autosport.com
Old 11-17-2011, 03:22 PM
JeremyD's Avatar
Thanks Jeff.
Old 11-17-2011, 03:44 PM
