brads911sc's Avatar
This was my problem with the entire concept.
If he is leaking, it could be because he is installing the shafts incorrectly.
Originally Posted by Walt Fricke View Post
However, HKZ, in order to install the short side plug you had to install the rocker shaft too far in. Your '72 has the long rocker shafts, same as succeeding 911s until the 993s. I think the short ones ended maybe in '67 or back then, in the 2.0 liter era.
A rocker shaft installed by the book will not have any of the shaft hole exposed on the short end for a cap to fit into. To do so, you had to cheat the shaft in a bit farther, moving the groove closer to the rocker itself. That could be a problem.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 12-07-2011, 08:24 PM
Walt Fricke's Avatar
If you are way off, you can't move the rockers. Guess how I know that?
I'd be a bit concerned if any of the slot were in the space between the two carrier holes. The rocker forces normally are transferred to the carrier via the full width of the rocker shaft. The slot reduces this substantially.
With that said, I once had a shaft get loose. I discovered this when it had moved far enough so the slot was where it shouldn't be, but it hadn't been there long and pushing it back into place and tightening the pinch bolt got me back on the track with no damage.
Old 12-07-2011, 10:11 PM
304065's Avatar
Here is rocker shaft dimension
Rocker shaft pinch bolts
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 12-08-2011, 02:57 AM
Chain fence eating turbo
Another idea we use in aviation; Caplugs.
Get a really heavy duty plastic plug from Caplugs that fits the bore but has a small flange that keeps the plug from going in deep.
Then, just add some non-hardening sealant like Hylomar. It would be a goopy mess when you went to remove them but it may hold in the oil.
The beauty of Hylomar is it easily wipes away with thinners, solvents, or like we use at my work, acetone.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 12-08-2011, 05:36 AM
