neilca's Avatar
Piston Squirters Again
This is how I invision the inside of a piston squirter. Can anyone confirm this is correct?
Old 12-26-2011, 07:07 AM
abit off center
cgarr's Avatar
When I removed mine and destroyed them in the process that's pretty much what they look like or at least how they work.
______________________
Craig
G2Performance
Old 12-26-2011, 08:48 AM
Piston oil squirters.......
The piston oil squirters look very similar to your diagram. However, they are no where close to the main oil galley/s. From the main oil galleys, oil travels to the through-bolt bores, a smaller bore connect to the through-bolt bore/s, and finally a second smaller bore goes to where the oil squirter sits. A member (billjam) had posted a very nice picture with illustration (Engine rebuild forum) that shows the oil passages to the squirters.
Tony
Old 12-26-2011, 10:50 AM
neilca's Avatar
Thanks guys,
Old 12-27-2011, 06:52 AM
