back fire
my 2.2 back fires a bit if the compression is bad whats the solution also the gear stick seems very floppy i,m not mechanically mined at all and i,m hoping to put the car into a garage but would like to understand a bit more before i do this.one other thing some thing seems to be stuck as revs higher than it use too thanks brian
Old 01-02-2012, 10:46 AM
