Piston ring end gap on 3.6L turbo build?
Currently building a 1994 3.6 liter M64/50 Turbo motor and plan on running 1 bar of boost. Here is a question I got from my builder today. Can anyone help. Thanks in advance.
"I would like to know if there might be a better head gasket to use. I have a Victor Reinz gasket set. The head gaskets look good, but is there something better that we should use. If you can check on this also. I need to know what is a good and safe piston ring end gap to run on the piston rings. The old rings that I removed from your engine showed little wear, the gap on them is, top ring .35mm 2nd ring .40mm bottom ring .50mm The new piston rings are Goetze rings 08-325100-00 the gap on these rings are. Top .33mm 2nd .33mm bottom .28mm I think that the ring end gap should be this and maybe a little more. top .40mm 2nd .40mm bottom .30mm This is going to be a lot higher boost engine then the stock one was so I would like to know what will be the best and the safest gap to run."
1965 911 Vin 1249 Slate Grey 1969 911 Golden Green 2.0 Twin Plug 1971 911 S Gold Metallic. Peter Gregg 1974 911 RS Euro Metallic Blue Gold lettering 1991 Brumos 3.6 Turbo Pikes Peak Zwart Motor |
I didn't have to file my Goetze rings cuz they gapped out fine and yours look fine too, but I'm sure a pro builder will chime in and tell you for sure. Also, the sealing rings for the heads in the VR gasket kit should be the ones you need. My 3.3 didn't have any sealing rings at all so I had fire rings added.
What's a rebuild cost estimate run these days?
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD 1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD 2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha Last edited by CaptainCalf; 01-26-2012 at 06:09 PM.. Reason: Add |
Henry? Steve? Can't anyone help with this info? Thanks
beancounter
http://www.aa1car.com/library/ringendgap_wiseco.pdf
I used non standard rings in my build that had to be gapped, which were supplied by Chris Carroll at Turbokraft. Chris gave me the recommended end gap specs which lined up very much with the table I linked above. I don't think there is anything particularly special about a turbo Porsche when it comes to piston ring end gap. The only thing I would say is, they run hot as hell. Given that, it seems to me that you want to err on the side of too large an end gap vs. too small.
Jacob Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690 Past: 2009 997 Turbo Cab / 1979 930 |
Max Sluiter
But the Aluminum should expand more than the steel so I would say that you would want a tight ring gap cold since it will only get larger with either heat or mileage.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
On Nikasil engines with hi compression I run these gaps if I can;
top ring .254 2nd .254 to .305 oil control .305 to .355 Never run less gap on the next ring down as problems like ring flutter could occur. Stock engines can have as little as .15 @ the top ring with a max of .4
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ |
Anyone with a better head gasket idea? thanks
Any turbo engine builders have an opinion? Thanks in advance.
Aaron or "Burn-Bros" (see his post above) is a professional, so you are getting top notch info right there.
What did you decide to do?
"Simplicity is supreme excellence" - James Watt |
