Seal Install Damage?
Did I just damage this seal installing it into the No. 8 nose bearing?
Or is it common and OK that some of the rubber ribs caught and cut on the outer surface?
1981 911sc RoW Coupe (forever under 3.6L conversion)
2003 996TT Basalt black
Old 02-01-2012, 08:35 PM
Try not, Do or Do not
Henry Schmidt's Avatar
It's very common. The install is not perfect but you should be fine.
Next time use Dow o-ring lubricant on the outside of the seal.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 02-01-2012, 09:04 PM
83 911 Production Cab #10
JJ 911SC's Avatar
If it worry you and will second guess yourself until the rebuild is finish, $15 for a new one is a good investment
Who Will Live... Will See
Old 02-02-2012, 02:29 AM
