ONQRACIng's Avatar
Timing chain issue
New build, 3.0 case, GT3 Crank, Elgine Cams. We have the case up to cams, and I just measured the spockets, Left reads 3.88 inch and right is perfect at 1.70 (per bently). Everthing looks good, but the right chain seems to "click" or bind on the sprocket. These are used sprockets, dont seem worn. I have Stomski Mech tensioners, and have them tight. Any ideas?
TIA
Old 01-30-2012, 11:18 AM
ONQRACIng's Avatar
got it
Old 01-30-2012, 03:00 PM
What was it??
Old 01-30-2012, 04:17 PM
ONQRACIng's Avatar
Thumbs up
Turns out, even though I was in spec for the right dimension, I was .020 off form the actual distance from int. shaft gear to face of the sprocket. Removed a shim, and all is well.. Running 4 shims on the left, and 2 on the right.. Now onto the timing of the cams. Should be ready for Motec by Friday.
Old 01-30-2012, 05:37 PM
Mechanical tensioners = track engine, yes?
Factory tensioners recommended for street-based engines.
S
Old 01-31-2012, 10:51 AM
ONQRACIng's Avatar
Yes, full track 3.6. We always run the Mechanical tensioners in our race engines.
Old 01-31-2012, 11:29 AM
