Considering Different Valves ?
Hi all,
I'am considering the potential to get mass out of the valve assemblies on my own car. I know and will apply the usual trick of titanium caps but have been wondering about sourcing and trying valves with smaller stems . Has anyone tried using say 7mm stem diameters ( obviously with smaller guides and seals ) . Any obvious pitfalls I am failing to see ?
Old 02-03-2012, 05:01 AM
304065's Avatar
Page Title
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 02-03-2012, 06:27 AM
The most obvious pitfalls to me are cost and durablility. I assume your car is air cooled. Smaller valve stems will not conduct heat as well as the larger ones. Much more likely to have a valve overheat and fail. A bit more information as to the engine type and purpose would help.
-Andy
Old 02-03-2012, 08:41 AM
Sorry yes that would be helpful, 2.8 twin plug, headers "s" cams . only need 2k per year, good quality fuel with lots of lead (I use avgas). Not a racer just for my own pleasure ?
Great work by extreme ther,e I'm not in that league
andy
Old 02-03-2012, 09:45 AM
Try not, Do or Do not
Henry Schmidt's Avatar
You could try some of these. Del West Titanium with Casidiam coated stems. Note the 9mm stems with 3 groove Porsche retainers (old school)
Weight comparison:
Intake 105 vs 68 grams
Exhaust 85 vs 58 grams
The last engine we built with these ran 200 hrs before a freshen up and the valves and seats were perfect. Even the bearings in the GT3 Titanium rods were perfect.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 02-03-2012, 10:10 AM
Kartoffelkopf
Spenny_b's Avatar
Originally Posted by haasad View Post
Hi all,
Hi, I'm getting my heads ported and rebuilt using Schrick hardware, Ti retainers, larger valves & associated springs. This is for a 964 Turbo (930 engine, more-or-less)
Being done by Richard Chamberlain @ CTR Developments up nr. Huntingdon. Would recommend giving Richard or his son Matthew a call and buying through them. This is the stuff he's been using in his own (935) and customer race engines for years and years, so very well proven.
Old 02-03-2012, 11:47 AM
PFM PFM is offline
PFM
PFM's Avatar
Haasad,
You might want to talk with Ferrea, they do some nice hollow stem valves.
Stay Tuned,
PFM
Old 02-03-2012, 07:18 PM
