johnman001's Avatar
Hardware Sources
Where do you source your metric hardware from?
I buy some hardware from our host, but where do you guys source your standard metric hardware (studs, nuts, washers, etc.) from?
I usually look at McMaster Carr, but their metric studs aren't really what I want. I would really like yellow zinc, 8.8 grade studs.
Thanks for your input.
John Flesburg
2016 981 Boxster S.................| 1983 911 Turbo - (White)
1974 911 3.2 - Red Car........... | 1974 914-6 3.2 - (Silver)
1974 914-6 3.2, GT -(Red).......| 1974 914 - 2.7 GT Clone (TBD - Saphire?)
1971 914 (TBD)..................... |
Old 02-05-2012, 08:44 PM
pete3799's Avatar
Local hardware store.
I guess i'm fortunate in that they have an incredible amount of metric fasteners on hand.
They had CV joint bolts, window channel bolts , trim screws,etc.
Pete
79 911SC RoW
Old 02-05-2012, 08:51 PM
KTL KTL is online now
Schleprock
KTL's Avatar
metricmcc.com
Sign up to get an account and you're all set. However, since they are an industrial supplier, you have to buy a minimum quantity/bulk. Pieces of 25 to 50 to 100 are common requirements.
Kevin L
'86 Carrera "Larry"
Old 02-06-2012, 06:49 AM
I must admit I recycle a lot. I inspect all the fasteners I have gathered over the year, clean them in a bead cleaner (an Eastwood vibrating bowl kind of thing) and then replace them in yellow zinc to match.
I can source fasteners locally, but some of the specific lengths are hard to buy in the smaller quantities (they want to sell me a box of 100 or something like that) and are frequently plated in silver.
D.
Old 02-06-2012, 07:01 AM
304065's Avatar
I have gone round and round on this- at the end of it, it's easier and cheaper to buy from Porsche, unless you need original headmarks. If you need original headmarks there is only one source, used pieces, which much be checked for necking down and corrosion.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 02-06-2012, 07:07 AM
Less brakes, more gas!
euro911sc's Avatar
Depends. For 1-10 pieces I'll get from pelican, dealer, or local hw store if available. For bulk stuff I order from MSC. Hard to beat their selection and price for bulk stuff. When I did the engine I just bought Pelican's HW kit. That was a good move.
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 02-06-2012, 11:52 AM
