richard003@wind's Avatar
Cool Cam tensioner question
I just installed hydraulic cam tensioners on an 83 3.0. When i put the newones on there is a space between the sprocket arm and the ring part of the new tensioner. How much is acceptable space? I have almost an eighth of an inch.
1979 911 SC... 83 911 SC .... 82 911 sc.... Fiat 124 Spider Full Race
Old 02-07-2012, 09:51 AM
MBEngineering's Avatar
HI richard
have you pulled the pin out of the tensioner?? or is the 1/8 on the shaft pin between the idler arm and the inside of the tensioner.
regards mike
Old 02-07-2012, 10:04 AM
The 83 has all the pieces to fit correctly. The usual problem is about 1/2 inch space that needs the spacer
This is the spacer senario
Bruce
Old 02-07-2012, 10:05 AM
That is were i have an tenth of an inch... Thanks. It just seems they should be less space inbetween them...
Old 02-07-2012, 10:09 AM
So, the small space I have is ok? Just need to make sure... Thanks Bruce for the picture.
Old 02-07-2012, 10:29 AM
KTL KTL is offline
Schleprock
KTL's Avatar
The small space is OK if you're sure the tensioner is seated all the way into the chain housing. Tap it with a rubber mallet to make sure. Then check the fitment of your chain housing cover with the o-ring removed from the chain tensioner port. Reason to remove the o-ring is to ensure it doesn't interfere with checking the fitment of the cover. The o-ring usually requires you to use some decent effort to seat cover.
Also, anybody else searching this thread should take some good advice and upgrade their idler arms if they are using the spacer that Bruce mentions. The old idler arms that are bushing-less are prone to binding. In Sept. I had my left idler arm bind on the shaft and cause my engine to lose power. It froze in a high-tension chain position, so thankfully the chain didn't go slack and jump timing.
Kevin L
'86 Carrera "Larry"
Old 02-07-2012, 10:50 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Bruce
A spacer scenario or a great place for a Supertec idler arm....
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 02-07-2012, 01:08 PM
Thank everyone for your replies.. all buttoned up for that part anyway...
Old 02-07-2012, 03:07 PM
