polizei's Avatar
Where to get camshaft rocker arms reconditioned?
Guys,
I live in the Philadelphia area, and I'm looking for a reputable shop that can inspect and recondition my camshaft rocker arms. Any suggestions? I don't mind shipping them out!
What should I expect in terms of cost?
Thanks!
Andy - 1987 911 Carrera Coupe
Old 02-25-2012, 10:25 AM
AlfonsoR's Avatar
There's a few people on this forum that might do it
1. Steve Weiner - Rennsport Systems Engine Services | Rennsport Systems | Porsche Performance Systems and Support
2. Camgrinder (Dougherty cams) Dougherty Racing Cams
3. cgarr on this forum, but I don't know his business name or details
"Simplicity is supreme excellence" - James Watt
Old 02-25-2012, 01:59 PM
Several folks can regrind the rocker tips. Fewer can reharden and regrind once the hardened surface is gone. Ask and let us know please. Webcam used to advertise that service, but I think new rockers were cheaper.
Sherwood
Old 02-25-2012, 02:05 PM
304065's Avatar
Send them to Verden Tool, they just did a few for me. They do a nice job.
121 East Blackwell Street Dover, NJ 07801
(973) 366-7510
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 02-25-2012, 02:10 PM
polizei's Avatar
Thanks for all the input guys. What's a reasonable price tag for reconditioning?
Old 02-25-2012, 05:21 PM
Sherwood
Hi Sherwood,
The rocker pads are not hardened from the factory; these cast iron parts are simply ground with a radius matching the cam lobes. In certain cases when using hard-welded cams, we hard-chrome the rocker pads to prevent failure.
FWIW,......New, OEM rocker QC has really slipped and we've noted that most of the new ones from the dealer are not ground correctly, leaving one side higher than the other. This results in most of the valve spring pressure being applied to one side of the pad and cam lobe, resulting in higher rates of failure.
Each and every new or used rocker arm now gets checked here to ensure the pads are straight and parallel with the rocker shaft centerline and cam lobes. Naturally, these are also rebushed as needed.
JMHO, but new ones aren't cheaper, especially when factoring the effort required to make sure they meet QC.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 02-25-2012, 05:48 PM
Originally Posted by Steve@Rennsport View Post
Hi Sherwood,
Steve, I wish I knew this a couple years ago, I would of had you QC and h. chrome my rockers when they were out and I saw pad surface failures. No wear on my camgrinder 964 cam. Do you recommend the "new" cgarr bushing type?
Sold: 1989 3.2 coupe, 112k miles
Old 02-26-2012, 06:52 AM
Hi Sherwood,
Steve,
Good to know. Thanks for the correction. Perhaps I was taking too many cues from WebCam as it relates to their hard weld regrinds.
While we're on the subject:
How much material can be removed before valve/rocker geometry and/or safety is compromised?
Can the valve stem be shortened to restore the correct geometry?
Sherwood
Old 02-26-2012, 09:53 AM
Henry,
I don't know what Craig uses for bushings, we use a material that's proven to be very durable for us.
Sherwood,
Webcam's hardweld material is VERY durable, however its a lot harder than the OEM rocker pad so hard-chroming these pads is mandatory for these things to live.
Not very much, about .002-.003. The valve stems really cannot be shortened enough to correct geometry; we only adjust valve lengths on hydraulic-lifter engines to keep the lifter inside its range after machining the seats.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 02-26-2012, 10:20 AM
Henry,
Sherwood,
Steve, Craig was/is developing the use of Garlock bushings for rockers. Exactly where the effort stands I don't remember.
Old 02-27-2012, 08:30 AM
John @ Costa-mesa machine
Tell it like it is or don't tell it at all.
Old 02-27-2012, 09:53 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Web Cam still does rocker servicing. Its on their page with the SOHC 12V 911 cam listing.
Craig uses Permaglide bushings in his rebushing.
Rocker arm bushing source
Seems to work pretty darn well. He's working on testing an additional type of bushing that chris_seven has sent him from the UK.
Kevin L
'86 Carrera "Larry"
Old 02-28-2012, 06:51 AM
burgermeister's Avatar
I rebushed my rocker arms (as well as the idler arms & sprockets) with the Garlock / Permaglide bushings, and I haven't had any issues in 9000 miles.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 03-02-2012, 03:08 PM
Good to know even the high speed application (sprocket) is working well with no early failures. I like the idea of the Permaglide, and will do that the next time I'm in there which could be never. Curious, did you just hone the rocker arm bushings after install to a slip fit, measured gap or do they become close enough after pressing in? Did you notice any decrease in valve train noise?
Old 03-02-2012, 04:11 PM
Jay's Precision Machine in Santa Clara Ca, (408-980-0743) specializes in redoing 911 rockers. Jerry Woods enterprises recommends and uses Jay. It is approx $300 to $350 to a full set. He replaces the bushings with a factory equivalent material and reams to size. Then the faces are resurface to be exactly correct with respect to the bushing centers. I have seen the finished product and they look great. He will be doing mine for my 911SC in the next few weeks. If you decided to use him tell him Matt from Santa Cruz recommended him. Jay is a mechanical engineer by education (I am a practicing ME). He does things the right way.
Matt
Old 03-03-2012, 11:15 AM
hcoles, the fit was perfect on every bushing, tested on a new rocker shaft.
Valve train noise didn't change, but I also used my old somewhat worn rocker shafts (rotated 180 degrees) in all but 1 location.
One word of caution is that the rocker face wears to fit the cam. Once the bushings are off by 8 thousands, and you press new bushings in, the rocker will need to re-wear to match the cam, causing lots of valve adjustments. If you have the cash, I'd get the arms refaced.
The idler sprocket and arm require a bit of trickery to get the garlock bushings to work. See:
idler arm bushing replacement
Old 03-03-2012, 02:12 PM
Doc Speed
Neil '67 911S's Avatar
Matt
Jay is a very capable machinist but be forewarned. Unless you are among his insiders, it could very well be many months before he returns your parts. It took him some 8 months to do two pairs of 912/356 heads, reface two sets of 356/912 rockers and reface a flywheel for me. Calling him once a week or every other week for a progress report results in nothing more than a big phone bill. And, he will only answer the phone around 5 PM PST. That said, however, he knows what he is doing. He was Harry Pellow "The Maestro's" machinist.
- Neil
'67 911S (Ol' Ivory)
'82 Hewlett Packard 34C
Old 03-11-2012, 06:09 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Supertec is now taking rocker rebuilds to a new level...........
The process is as follows.
Remove old bushing and adjuster
Black Oxide rocker
Clean threads with a forming tap.
Replace bushing with high quality friction reducing DU bushing.
Surface contact pad.
Dry film Moly coat pad
Cryo treat entire assembly
We can rebuild yours or exchange from stock on hand, quick turnaround (same day) if exchanged.
We can also micro polish rockers shafts..
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 03-29-2012, 05:41 AM
What is the cost for your rocker rebuild exchange service Henry?
Old 03-29-2012, 08:42 PM
We developed this process for in-house rebuilds and it's a new deal for us. My thinking is that they should cost about $30/ea when done as a set.
I'm negotiating to buy a Cryo business so that will help control costs and speed up turn-around.
Henry Schmidt
Ph: 760-728-3062
Old 03-30-2012, 07:28 AM
