911 tweaks's Avatar
How do I correlate AFR to CO content...?? using a LM-2...
maybe I am mixing apples & oranges here, but, I am trying to set AFR on a 3.2L to 12-13...I understand that stociometric(sp) of 14.7 is perfect and it equals 1 per the instructions with my LM-2 unit...
I have read & been advised that at idle speed of 900-1k rpm's I want my AFR measurement to be around 12-13...
What does a CO reading of 2-2.5% equate to in terms of AFR...??
Thx, Bob
I live for 911 tweaks...
Old 05-03-2012, 04:46 AM
356RS's Avatar
Co% 2 = 13.77 afr; co% 2.5 = 13.56 afr.
Mark Jung
Bend, OR
MFI Werks.com
Old 05-03-2012, 09:47 AM
911 tweaks's Avatar
thx Mark...is there a conversion factor or a way I can convert afr to Co...??
What would the Co be for a 14.7 afr...??
Also, what is the afr for 1% Co; 1.5% Co and 3% Co...??
Thx Mark...these appear to not be linear...??
Bob
Old 05-03-2012, 09:56 AM
356RS's Avatar
Bob, I have a CO% / AFR Table that I can e-mail to you. The CO for 14.72 AFR is 0.1 CO%. The AFR for 1% CO= 14.11; 1.5% CO= 13.94; 3% CO= 13.38
Mark Jung
Bend, OR
MFI Werks.com
Old 05-03-2012, 10:06 AM
911 tweaks's Avatar
Thx Mark...please email me the table at bobf@design-associates-ne.com...
Basically, I am having trouble setting the mixture on a 1984 3.2L Carrera...my LM-02 initially had issues & was found to have a faulty cable for the o2 sensor...I found 1 vacuum leak & fuel pressure reg was bad...still experiencing a low idle speed & very lean mixture readings at a warmed up idle with mixture screw turned all the way in...when I drive car & put it under load = accelerate, the afr goes to 1 to 4 afr's...at idle or coasting it is 18-21 afr...
Any ideas on what to check...?? I have checked ALL vacuum hoses & ALL sensors on engine & all "seem" to be working w/in spec...
Thx, Bob
Old 05-03-2012, 10:53 AM
AlfonsoR's Avatar
I copied this from BemariM3Ex: http://www.bemarim3ex.com/demos/repair-new-bemarim3ex-141/39-afr-vs-co-table.html
%CO AFR
0.1 14.72
0.2 14.54
0.3 14.42
0.4 14.34
0.5 14.28
0.6 14.23
0.7 14.21
0.8 14.17
0.9 14.15
1 14.11
1.1 14.09
1.2 14.04
1.3 14.01
1.4 13.98
1.5 13.94
1.6 13.89
1.7 13.86
1.8 13.82
1.9 13.8
2 13.77
2.1 13.73
2.2 13.69
2.3 13.63
2.4 13.59
2.5 13.56
2.6 13.54
2.7 13.49
2.8 13.45
2.9 13.41
3 13.38
3.1 13.34
3.2 13.31
3.3 13.27
3.4 13.24
3.5 13.2
3.6 13.15
3.7 13.12
3.8 13.08
3.9 13.03
4 13
4.1 12.96
4.2 12.93
4.3 12.9
4.4 12.86
4.5 12.83
4.6 12.8
4.7 12.75
4.8 12.7
4.9 12.66
5 12.64
5.1 12.59
5.2 12.54
5.3 12.51
5.4 12.46
5.5 12.43
5.6 12.4
5.7 12.37
5.8 12.3
5.9 12.25
6 12.25
6.1 12.22
6.2 12.18
6.3 12.13
6.4 12.1
6.5 12.09
6.6 12.03
6.7 12
6.8 11.96
6.9 11.93
7 11.89
7.1 11.86
7.2 11.82
7.3 11.79
7.4 11.76
7.5 11.72
7.6 11.69
7.7 11.65
7.8 11.61
7.9 11.58
8 11.54
8.1 11.5
8.2 11.46
8.3 11.43
8.4 11.4
8.5 11.36
8.6 11.32
8.7 11.28
8.8 11.25
8.9 11.21
9 11.16
9.1 11.12
9.2 11.08
9.3 11.05
9.4 11.01
9.5 10.97
9.6 10.94
9.7 10.9
9.8 10.86
9.9 10.82
10 10.79
"Simplicity is supreme excellence" - James Watt
Old 05-03-2012, 08:23 PM
304065's Avatar
Remember that the stochiometric mixture of E10 will be richer than pure gasoline.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 05-04-2012, 06:00 AM
911 tweaks's Avatar
304065...good point...how do I factor your input = E10 fuel these days into the tables here...??
Thx, Bob
Old 05-04-2012, 06:06 AM
al lkosmal's Avatar
Why not just change the mode of the LM-2 so that you can read AFR directly? Or am i missing something here?
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 05-04-2012, 06:50 PM
911 tweaks's Avatar
...you are right Al...however, I am having trouble...STILL...with my brand new LM-2 unit & trying to figure it out...I am as certain as possible that the engine is sound but for the life of me I cannot adjust the fuel mixture then the idle...ARGHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH...
I am about to run over the f'ng pos unit... :-) But I wont...it will probably turn out to be me not understanding something & I cannot figure this thing out...!!!
I think I need to find a local speed shop that has a known good exhaust reader so I can set mixture & then idle...
I found several cracked vacuum hoses...replaced them...fuel pressure reg was bad...replaced it... new spark plugs...I checked ALL sensors & w/in range per bently...just installed a cat bypass pipe as cat was plugged & still better but not correct mix & idle...
Anyone want to take a stab at this with me using my LM-2...I have the tail pipe clam that Al K. suggested to get & the rpm clamp...
Just when I thought it was going to get easy I am hitting my head against a wall...
Old 05-05-2012, 03:18 PM
Dr J's Avatar
911 tweaks:
I have had an LM-2 sorted out and running on my car continuously for over a year with the O2 sensor on my cat bypass. I would be happy to help you out. Email me or pm me.
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged!
Old 05-06-2012, 06:40 PM
911 tweaks's Avatar
pm sent to DrJ...thx
Old 05-06-2012, 06:44 PM
911 tweaks's Avatar
Thx again John...you were a great help...best of luck with your work in FL... Bob
Old 05-08-2012, 04:04 PM
Dr J's Avatar
My pleasure. Hope you get the rest sorted out and can enjoy the car.
Old 05-09-2012, 06:57 PM
911 tweaks's Avatar
...FINALLY found out what it was...it is going to sound quite obvious...intake runner seals dried out ~ cracked = leaking air...!!
I sprayed carb cleaner around the base gaskets & no idle spike...I initially sprayed a shot into the air box & the idle spiked so I knew the engine would spike "IF" a leak where sprayed...nope...
A buddy told me that carb cleaner is not as volatile as it used to be...try brake clean...so, we gave the intakes a shot with brake clean and WHAM...SPIKE...
Thought I would pass this along so others are not fooled when trying to perform a similar diagnosis...
Thx again everyone... Bob
Old 05-10-2012, 05:16 AM
Dr J's Avatar
Congrats!
Old 05-10-2012, 03:51 PM
