930 Oil Pump Rebuld
Can anybody tell me how to locate parts to rebuild my turbo pump?
I've searched but can find a rebuild thread and as for the pump I can find the whole thing, but can't find internal parts for either 930-107-008-70 or 996-107-008-70. I need keys for keyways and one of the long gears has some pitting on it so I'd like to replace it...it's the longer gear in the pic standing upright that goes on the splined drive shaft, but it looks like both long gears are the same on both shafts... Thanks, RC
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD 1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD 2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha |
Are you looking to replace the key or have you not found it? I'm pretty sure its in one of the parts boxes if its the latter.
The long gears are for the scavenge side of the pump so the small pits in the one gear shouldn't be an issue if you are worried about reusing it. |
![]() That's great news on the long scavenge side gear cuz I can't find parts anyways...guess they want you to buy the whole pump
RC I hope you kept a track of which gear came off which spindle as they are pretty much matched to mesh with each other (ask me how I know) and if not replaced in the same order they came off then could cause binding problems.
Davy 82 911 SC Targa Sold 12 Audi A5 Sportback 3.0 TDI Quattro 03 996 C4S |
Thanks, RC
RC obviously big goes to big and small to small but the actual gear mesh is what I am on about. I took the old pump out my sc as it was shot and opened it up to have a look at the internals. Beofre taking it apart the gears spun easily.
I did not mark the line up of the gears before removing them from the spindles and after re-assembling the gears were binding on each other. I subsequently bought a good used pump and disassembled this time marking the end of the gears, cleaned everything up lubed and reassembled and had no issues with binding. It seems that the 28 years the gears had been spinning had bedded each tooth to it corresponding partner and did not like being mated with another. Thats why I said ask me how I know....
Schleprock
Yep, the thing that stinks is that the 930 pump is no more. Porsche says its NLA and you are therefore superseded to the 996 Turbo pump. Not saying that's a bad thing, just pointing out the original 930 pump is no longer in production.
Pelican Parts - Automotive Parts and Accessories - Porsche & BMW
Kevin L '86 Carrera "Larry" |
Schleprock
I think the catalog is incorrect in that the one you linked is the GT3 pump (which is the next step up and supposed to be the hot setup) but it says 2001-2005 Turbo?
I haven't done one but I recall reading that the GT3 pump requires some additional clearancing in the case? I didn't gather that being a big deal, but it should be mentioned nonetheless. So, yes, for the additional $ the GT3 is supposed to be the cat's meow, bee's knees, the hot ticket, etc. etc. yadda yadda yadda
I did find a used GT3 pump, but not sure what it would take to make it fit my 1987 930 case.
Also, my 930 pump seems to be fine with no binding, so after some more testing I may just stick with it. Thanks, RC
When I pulled my pump apart (4 rib aluminium) the gears were
marked by a circle. All these circles are roughly 'up' at the same time. ![]() IMG_3933, on Flickr andy |
Thanks Andy, I'll look for those little circles. Any more pics of it showing the key or keys that go in the 5mm wide key ways? I need to track down some, so thanks in advance for your help. RC
Try not, Do or Do not
Let me know exactly what parts you need. I'm certain I can supply them "no matter how much it costs".
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
![]() I need one of the longer 5mm wide keys that goes in the 65mm long key way on the shaft inside the pump to lock the gears on the shaft. Thanks, RC
So what exactly is done when one of these pumps are blueprinted? Is it just machining the case for proper clearance? Or is there much more to it?
I'd be interested in that answer too. I've read that you can skim the housing to remove play, but not sure blueprinting would be required to do that...RC
Schleprock
Here's the shimming description I once saw. Haven't had a chance yet to see what's involved in doing it.
See YTNUKLR's post at the very bottom Internal Oil Pump
The GT3 pump requires removing some of the internal case webbing. You can do it yourself with a die grinder. This pump is even longer than the 930 pump (though it uses the same tubular splined connecting shaft) so it needs a bit more room. I clearanced a regular 3.0 case (which, of course, has a 930 casting number even though not a turbo case) for one and used a saw to start with to cut down on the grinding, so I don't know just how much less is needed with a case which came from Porsche machined for the 930 pump.
I think that purchasing good used parts from some kind soul like Henry is the only way to get parts for 911 oil pumps. Parts for them were never sold separately by Porsche, and I am pretty sure the pumps were made specifically for Porsche rather than being made up of more general purpose parts. |
![]() here's some pics of the keyway for the missing key ![]()
