CaptainCalf's Avatar
930 Oil Pump Rebuld
Can anybody tell me how to locate parts to rebuild my turbo pump?
I've searched but can find a rebuild thread and as for the pump I can find the whole thing, but can't find internal parts for either 930-107-008-70 or 996-107-008-70.
I need keys for keyways and one of the long gears has some pitting on it so I'd like to replace it...it's the longer gear in the pic standing upright that goes on the splined drive shaft, but it looks like both long gears are the same on both shafts...
Thanks,
RC
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD
1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD
2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha
Old 03-28-2011, 05:51 AM
350HP930's Avatar
Are you looking to replace the key or have you not found it? I'm pretty sure its in one of the parts boxes if its the latter.
The long gears are for the scavenge side of the pump so the small pits in the one gear shouldn't be an issue if you are worried about reusing it.
Old 03-28-2011, 09:02 AM
Thanks Tony, I'll track down those keys
That's great news on the long scavenge side gear cuz I can't find parts anyways...guess they want you to buy the whole pump
Old 03-28-2011, 09:07 AM
Daviboy's Avatar
RC I hope you kept a track of which gear came off which spindle as they are pretty much matched to mesh with each other (ask me how I know) and if not replaced in the same order they came off then could cause binding problems.
Davy
82 911 SC Targa Sold
12 Audi A5 Sportback 3.0 TDI Quattro
03 996 C4S
Old 03-28-2011, 09:09 AM
Good point Daviboy, I think the same gear sizes were matched up side by side big meshed with big and small with small, but just to make sure can anybody out there open one up and provide us with a picture?
Thanks,
RC
Old 03-28-2011, 09:16 AM
Daviboy's Avatar
RC obviously big goes to big and small to small but the actual gear mesh is what I am on about. I took the old pump out my sc as it was shot and opened it up to have a look at the internals. Beofre taking it apart the gears spun easily.
I did not mark the line up of the gears before removing them from the spindles and after re-assembling the gears were binding on each other. I subsequently bought a good used pump and disassembled this time marking the end of the gears, cleaned everything up lubed and reassembled and had no issues with binding. It seems that the 28 years the gears had been spinning had bedded each tooth to it corresponding partner and did not like being mated with another. Thats why I said ask me how I know....
Davy
03 996 C4S
Old 03-28-2011, 09:51 AM
Oops, didn't even think about the mating of the teeth over the years. Guess it's time to upgrade pumps
Old 03-28-2011, 10:25 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Yep, the thing that stinks is that the 930 pump is no more. Porsche says its NLA and you are therefore superseded to the 996 Turbo pump. Not saying that's a bad thing, just pointing out the original 930 pump is no longer in production.
Pelican Parts - Automotive Parts and Accessories - Porsche & BMW
Kevin L
'86 Carrera "Larry"
Old 03-28-2011, 10:33 AM
I noticed that when looking for replacement gears, but wouldn't it be smarter to go ahead and get the next level pump?
Old 03-28-2011, 10:40 AM
KTL KTL is offline
Schleprock
KTL's Avatar
I think the catalog is incorrect in that the one you linked is the GT3 pump (which is the next step up and supposed to be the hot setup) but it says 2001-2005 Turbo?
I haven't done one but I recall reading that the GT3 pump requires some additional clearancing in the case? I didn't gather that being a big deal, but it should be mentioned nonetheless. So, yes, for the additional $ the GT3 is supposed to be the cat's meow, bee's knees, the hot ticket, etc. etc. yadda yadda yadda
Kevin L
'86 Carrera "Larry"
Old 03-28-2011, 10:47 AM
I did find a used GT3 pump, but not sure what it would take to make it fit my 1987 930 case.
Also, my 930 pump seems to be fine with no binding, so after some more testing I may just stick with it.
Thanks,
RC
Old 03-29-2011, 06:31 AM
When I pulled my pump apart (4 rib aluminium) the gears were
marked by a circle. All these circles are roughly 'up' at the
same time.
IMG_3933, on Flickr
andy
Old 03-29-2011, 03:25 PM
same time.
IMG_3933, on Flickr
andy
Thanks Andy, I'll look for those little circles. Any more pics of it showing the key or keys that go in the 5mm wide key ways? I need to track down some, so thanks in advance for your help.
RC
Old 03-30-2011, 06:46 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Let me know exactly what parts you need. I'm certain I can supply them "no matter how much it costs".
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 03-30-2011, 08:06 AM
LOL! Henry, I'd say you have about anything anybody would want
I need one of the longer 5mm wide keys that goes in the 65mm long key way on the shaft inside the pump to lock the gears on the shaft.
Thanks,
RC
Old 03-30-2011, 08:19 AM
So what exactly is done when one of these pumps are blueprinted? Is it just machining the case for proper clearance? Or is there much more to it?
Old 03-30-2011, 12:34 PM
I'd be interested in that answer too. I've read that you can skim the housing to remove play, but not sure blueprinting would be required to do that...RC
Old 03-30-2011, 12:45 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Here's the shimming description I once saw. Haven't had a chance yet to see what's involved in doing it.
See YTNUKLR's post at the very bottom
Internal Oil Pump
Kevin L
'86 Carrera "Larry"
Old 03-30-2011, 12:50 PM
Walt Fricke's Avatar
The GT3 pump requires removing some of the internal case webbing. You can do it yourself with a die grinder. This pump is even longer than the 930 pump (though it uses the same tubular splined connecting shaft) so it needs a bit more room. I clearanced a regular 3.0 case (which, of course, has a 930 casting number even though not a turbo case) for one and used a saw to start with to cut down on the grinding, so I don't know just how much less is needed with a case which came from Porsche machined for the 930 pump.
I think that purchasing good used parts from some kind soul like Henry is the only way to get parts for 911 oil pumps. Parts for them were never sold separately by Porsche, and I am pretty sure the pumps were made specifically for Porsche rather than being made up of more general purpose parts.
Old 03-30-2011, 01:18 PM
Thanks Walt, that GT3 pump would be sweet, but at $1349.00 at my local dealer I think I'm gonna try to stick with this 930 pump
here's some pics of the keyway for the missing key
Old 03-31-2011, 08:24 AM
