Weber Inlet Manifolds
I am looking to fit Weber 40 IDA type cars to an early 3.0SC.
I have original Weber Inlet Manifolds with a 32mm outlet to match an early port.
The engine I have has 39mm ports.
I have some spacers to blank off the injector and avoid air leaks.
Do I need to open the manifolds to match or can I leave them alone.
The engine has standard SC pistons and cams.
Old 06-18-2012, 06:25 AM
Wer bremst verliert
JohnJL's Avatar
You should match the manifolds to the ports on the heads. You can do this by modifying the phenolic spacers, or the more dramatic step of modifying the manifolds. I'd suggest not molesting the 32mm manifolds, sell those to someone with the smaller head ports and purchase other manifolds which will match with no or less modification.
You are leaving a lot on the table by not changing cams, and a bit by not changing pistons. I have a similar motor to yours running webers with DC60 cams, its a huge improvement over the stock SC cams.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 06-18-2012, 06:40 AM
ASE Master Tech - 35 yrs
larrym's Avatar
2X that
- find a set of PMO's that match your ports
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 07-09-2012, 11:25 PM
Grand Am/IMSA Data Guy
Porsche84's Avatar
WQebber intake manifolds
THESE MANIFOLDS HAVE SOLD*****
I have this set, not sure what the are for. I just cleaned them and measured each opening. This is all I have, no other bits to go with them. If you want them, make me an offer, I just have no idea what they are worth.
Jerry Austin
AIM Data Products Dealer
84 911 3.6 track car - Sold
Morris Minor Van with S2000 running gear
http://austinmotorsportsllc.com/
Old 07-30-2012, 06:18 PM
