-   -   Saving a 906 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/686273-saving-906-a.html)
Gary De 07-05-2012 07:56 AM
Henry, that is pure art work!!!! It apears that the top of the piston has a coating along with the skirt area. The skirt looks black. Are you using some type of dry film lube on the skirt and a thermal barrier on the top?
KTL 07-05-2012 09:13 AM
Pretty stuff! Thanks for sharing how you check piston & deck clearance with the red clay.
Also notice the thermostat blockoff RSR piece. That means this engine will be running an oil filter console, or will the oil cooler simply be flowing at all times?
I like how the small displacement engines have so much "meat" around the piston bores. The larger displacement engines have always bugged me with how close are the head stud holes to the piston bore OD.
daepp 07-05-2012 09:36 AM
Excuse my ignorance, but is this actually going into a 906?
Beautiful engine BTW!
Henry Schmidt 07-05-2012 09:42 AM
http://forums.pelicanparts.com/uploa...1341506181.jpg
http://forums.pelicanparts.com/uploa...1341506263.jpg
http://forums.pelicanparts.com/uploa...1341506230.jpghttp://forums.pelicanparts.com/uploa...1341506324.jpg
http://forums.pelicanparts.com/uploa...1341506353.jpg
Sometimes fine tuning is required
http://forums.pelicanparts.com/uploa...1341506387.jpg
http://forums.pelicanparts.com/uploa...1341506438.jpg
http://forums.pelicanparts.com/uploa...1341506462.jpg
http://forums.pelicanparts.com/uploa...1341506483.jpg
Henry Schmidt 07-05-2012 09:52 AM
http://forums.pelicanparts.com/uploa...1341506602.jpg
http://forums.pelicanparts.com/uploa...1341506623.jpg
http://forums.pelicanparts.com/uploa...1341506644.jpg
http://forums.pelicanparts.com/uploa...1341506667.jpg
http://forums.pelicanparts.com/uploa...1341506687.jpg
http://forums.pelicanparts.com/uploa...1341506740.jpg
http://forums.pelicanparts.com/uploa...1341507072.jpg
http://forums.pelicanparts.com/uploa...1341507095.jpg
http://forums.pelicanparts.com/uploa...1341507112.jpg
Henry Schmidt 07-05-2012 09:57 AM
Hi Dave
Yes sir, 906 0022
KTL 07-05-2012 10:18 AM
Originally Posted by Henry Schmidt (Post 6840633)
There's my answer. Factory Porsche multi-screen filter console.
Henry Schmidt 07-05-2012 10:29 AM
The pistons are coated with a thermal barrier and dry film lubricant. We also coat the bearings and rocker pads as well as the cam lobes.
The valve stems are also coated with dry Moly.
Henry Schmidt 07-05-2012 10:42 AM
We also did the trans:
http://forums.pelicanparts.com/uploa...1341509629.jpg
http://forums.pelicanparts.com/uploa...1341509648.jpg
http://forums.pelicanparts.com/uploa...1341509750.jpg
http://forums.pelicanparts.com/uploa...1341509763.jpg
http://forums.pelicanparts.com/uploa...1341509773.jpg
http://forums.pelicanparts.com/uploa...1341509827.jpg
http://forums.pelicanparts.com/uploa...1341509902.jpg
http://forums.pelicanparts.com/uploa...1341509914.jpg
http://forums.pelicanparts.com/uploa...1341509930.jpg
http://forums.pelicanparts.com/uploa...1341509942.jpg
LJ851 07-05-2012 11:02 AM
Henry, what coating/plating are you using on the mag parts? Looks really nice.
Henry Schmidt 07-05-2012 11:16 AM
The coating is a Dow product that was contracted by the shop doing the body restoration. Sorry I can't be more helpful.
tadd 07-06-2012 08:18 AM
Henry,
One more question if I may please.... Lash caps. Did you reuse what was there or did you need to replace them? If you did change them, might you share where you got them?
I will be needing to do this process myself soon.
Make that two questions...Were the tensioners for authenticity? In other words why not use solids given it's going into a 'real' car that will see maintenance respectful of use.
tadd
Henry Schmidt 07-06-2012 09:07 AM
Originally Posted by tadd (Post 6842390)
Henry,
tadd
We were fortunate enough to source NOS valves so we needed to adjust every valve. We used what we had by dancing them around and hand lapping for precise measurements. That left us needing 4 specific sizes. With those numbers in hand we just ordered the sizes we needed from Porsche Motorsport.
We used hydraulic tensioners because they work well under these circumstances: occupational racing and short runs without warm up. IE: "check out how cool my 906 sounds".
daepp 07-06-2012 10:34 AM
I should probably know this, but do you test run your motors before they go back out? IF so, you REALLY need to record that sound!
Henry Schmidt 07-06-2012 11:48 AM
Engines shipped from my shop re ship dry and untested unless the customer requests a dyno test.
In this case, his race mechanic will tune the engine.
Zitzit 07-13-2012 04:26 AM
Hello!
is there any chance to have a picture of the center lube cam to chain housing seals. They are known to be unobtanium and never saw one...
Another question, hos did you do to "replicate" the 906 crank? is that something you are able to make on order? if yes, would you send me details by PM?
Thanks a lot!
olivier.
dinobx 07-13-2012 05:07 AM
Hello Henry,
Absolutely beautiful work you're doing. Quick question. I thought we were all supposed to use a five or six arm engine yolk to hold the engine on the stand. Yours is just four arm. Any insight?
Thanks.
Dino
YTNUKLR 07-13-2012 11:41 PM
Is there anything special to the 906 trans? It looks different from a 901 outside, but the gear stack looks the same. Is that a one-piece bearing retainer? In 1966?
chris_seven 07-14-2012 12:26 AM
http://i197.photobucket.com/albums/a...e/Demolish.jpg
Great picture - reminds me of a similar photograph in a very early Honda CB72 manual in a chapter titled 'How to Demolish the Engine' :)
fanaudical 07-14-2012 08:11 AM
Beautiful work! Thank you for sharing.
