Henry, that is pure art work!!!! It apears that the top of the piston has a coating along with the skirt area. The skirt looks black. Are you using some type of dry film lube on the skirt and a thermal barrier on the top?
Schleprock
Pretty stuff! Thanks for sharing how you check piston & deck clearance with the red clay.
Also notice the thermostat blockoff RSR piece. That means this engine will be running an oil filter console, or will the oil cooler simply be flowing at all times? I like how the small displacement engines have so much "meat" around the piston bores. The larger displacement engines have always bugged me with how close are the head stud holes to the piston bore OD.
Kevin L '86 Carrera "Larry" |
Excuse my ignorance, but is this actually going into a 906?
Beautiful engine BTW!
David 1972 911T/S MFI Survivor |
Try not, Do or Do not
![]() ![]() ![]() ![]() ![]() Sometimes fine tuning is required ![]() ![]() ![]()
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Yes sir, 906 0022
Schleprock
There's my answer. Factory Porsche multi-screen filter console.
The valve stems are also coated with dry Moly.
We also did the trans:
The coating is a Dow product that was contracted by the shop doing the body restoration. Sorry I can't be more helpful.
Henry,
One more question if I may please.... Lash caps. Did you reuse what was there or did you need to replace them? If you did change them, might you share where you got them? I will be needing to do this process myself soon. Make that two questions...Were the tensioners for authenticity? In other words why not use solids given it's going into a 'real' car that will see maintenance respectful of use. tadd
1967 912 with centerlocks… 10 years and still in pieces! |
We used hydraulic tensioners because they work well under these circumstances: occupational racing and short runs without warm up. IE: "check out how cool my 906 sounds".
I should probably know this, but do you test run your motors before they go back out? IF so, you REALLY need to record that sound!
In this case, his race mechanic will tune the engine.
Hello!
is there any chance to have a picture of the center lube cam to chain housing seals. They are known to be unobtanium and never saw one... Another question, hos did you do to "replicate" the 906 crank? is that something you are able to make on order? if yes, would you send me details by PM? Thanks a lot! olivier. |
Hello Henry,
Absolutely beautiful work you're doing. Quick question. I thought we were all supposed to use a five or six arm engine yolk to hold the engine on the stand. Yours is just four arm. Any insight? Thanks. Dino |
up-fixing der car(ma)
Is there anything special to the 906 trans? It looks different from a 901 outside, but the gear stack looks the same. Is that a one-piece bearing retainer? In 1966?
Scott Kinder kindersport @ gmail.com |
![]() Great picture - reminds me of a similar photograph in a very early Honda CB72 manual in a chapter titled 'How to Demolish the Engine'
Beautiful work! Thank you for sharing.
