Try not, Do or Do not
The major difference is the 904 main shaft, gear ratios and the additional oiling hole in the intermediate plate to lubricate the main shaft bearing. This design feature was transferred to the mid-engine transmissions used in the 914/6 but not the 914 /4 cylinder cars. As you look at the case you will notice that it has extra fins for cooling and structural rigidity. Although it looks similar to the 901 aluminum case, it is in fact sand cast magnesium. There are also additional bosses for mounting the trans into the chassis. Looking at the shift selection fork you'll notice a large bolt in the center. That is an additional detent designed to aid in rapid shift selection. Looking through the hole you might be able to notice that the LSD is tiny. It is haft the diameter of the 901/915 LSD ad half the weight. The output shafts protrude from the differential unlike the production piece. These shafts have an external spline design adapted from the 904. I believe the flanges are identical to the 904. The last major difference is the provision for the shift shaft. As you can see, the shift shaft is accessed under the bell housing. this design is different from either the tail shifter or side shifter of the production models.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
This adjustment technique proves that "old habits die hard."
I use only 3 and 4 arm German made yokes. After 30+ years in the business I have never had or seen a problem. If you're buying a cheaper Chinese made yoke perhaps extra reinforcements makes sense. I really don't know.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 07-14-2012 at 11:39 PM.. |
Max Sluiter
What was he adjusting with the hammer?
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Endplay....
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ |
Wer bremst verliert
Hi Henry,
Do you have a pic of the combustion chambers? Those pistons have a huge dome. Whats the compression? Thanks John
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
Cam Chains
Henery
It appears thgat you are using aluminum chain wheels. The 1973, and later RSR also uses those aluminum wheels. The RSR parts book shows an unusual Porsche part number for the RSR chains. Different from a normal split chain, or non split chain. Do you know why the RSR has a different chain number? Do you use anything special chain wise for the aluminum wheels in your engines, Mike Curnow |
I forget what its called but its a standard coating for protecting mag. I think its called gold wash or something. I know you can order it from West Marine. There has been allot of discussion about using it on mag wheels before painting/powder coating. You can do a search. I know we discussed it at length on the NSR forum.
james www.gruppe9autowerks.com Its not how fast you go...its how you go fast |
Second answer
James
Apparently you like to answer other peoples questions, INTERNET expert I guess. This is the second question I asked that you have answered, incorrectly. If you insist on doing this, read the question. What is unique about the 1973 , 74, 75 cam chain? Part # 901 105 529 02, that part number is not the solid or split chain part number. I thought it may have something to do with the aluminum chain wheels since they are the only real unique pieces in the RSR valve train. Anyone have any facts, and not opinions? Quote:
sorry
Sorry, I thought you were answering my question to Henry. Mike |
The heads are basically the same as a 69 chamber with 12mm plug holes. The compression was measured @ 10.8:1.
993-105-529-00/255
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 07-18-2012 at 12:54 PM.. |
Dow 7 is a chemical conversion coating which results in no appreciable dimensional change to the component. The surface of components coated with Dow 7 is changed to a brassy or dark brown finish depending on the alloy.
![]() ![]() ![]() The crank was made from a std/std 2.2 911 "S" crank. It can be replicated for around $1.2K if you supply the crank.
Magnesium protection
gearhead
I really hope that some day I've got a good excuse to have Henry build an engine for me...
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Matt - you will NOT be disappointed!
Hope you don't mind, Henry - it was a great experience (and mine was just a lowly T). ![]() ![]() ![]()
David 1972 911T/S MFI Survivor |
