Henry, that is pure art work!!!! It apears that the top of the piston has a coating along with the skirt area. The skirt looks black. Are you using some type of dry film lube on the skirt and a thermal barrier on the top?
Old 07-05-2012, 07:56 AM
KTL KTL is online now
Schleprock
KTL's Avatar
Pretty stuff! Thanks for sharing how you check piston & deck clearance with the red clay.
Also notice the thermostat blockoff RSR piece. That means this engine will be running an oil filter console, or will the oil cooler simply be flowing at all times?
I like how the small displacement engines have so much "meat" around the piston bores. The larger displacement engines have always bugged me with how close are the head stud holes to the piston bore OD.
Kevin L
'86 Carrera "Larry"
Old 07-05-2012, 09:13 AM
Excuse my ignorance, but is this actually going into a 906?
Beautiful engine BTW!
1972 911T/S MFI Survivor
Old 07-05-2012, 09:36 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Sometimes fine tuning is required
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 07-05-2012, 09:42 AM
Henry Schmidt
Ph: 760-728-3062
Old 07-05-2012, 09:52 AM
Hi Dave
Yes sir, 906 0022
Henry Schmidt
Ph: 760-728-3062
Old 07-05-2012, 09:57 AM
Schleprock
KTL's Avatar
Originally Posted by Henry Schmidt View Post
There's my answer. Factory Porsche multi-screen filter console.
Kevin L
'86 Carrera "Larry"
Old 07-05-2012, 10:18 AM
The pistons are coated with a thermal barrier and dry film lubricant. We also coat the bearings and rocker pads as well as the cam lobes.
The valve stems are also coated with dry Moly.
Henry Schmidt
Ph: 760-728-3062
Old 07-05-2012, 10:29 AM
We also did the trans:
Henry Schmidt
Ph: 760-728-3062
Old 07-05-2012, 10:42 AM
LJ851's Avatar
Henry, what coating/plating are you using on the mag parts? Looks really nice.
Old 07-05-2012, 11:02 AM
The coating is a Dow product that was contracted by the shop doing the body restoration. Sorry I can't be more helpful.
Henry Schmidt
Ph: 760-728-3062
Old 07-05-2012, 11:16 AM
tadd's Avatar
Henry,
One more question if I may please.... Lash caps. Did you reuse what was there or did you need to replace them? If you did change them, might you share where you got them?
I will be needing to do this process myself soon.
Make that two questions...Were the tensioners for authenticity? In other words why not use solids given it's going into a 'real' car that will see maintenance respectful of use.
tadd
1967 912 with centerlocks… 10 years and still in pieces!
Old 07-06-2012, 08:18 AM
Originally Posted by tadd View Post
Henry,
tadd
We were fortunate enough to source NOS valves so we needed to adjust every valve. We used what we had by dancing them around and hand lapping for precise measurements. That left us needing 4 specific sizes. With those numbers in hand we just ordered the sizes we needed from Porsche Motorsport.
We used hydraulic tensioners because they work well under these circumstances: occupational racing and short runs without warm up. IE: "check out how cool my 906 sounds".
Henry Schmidt
Ph: 760-728-3062
Old 07-06-2012, 09:07 AM
I should probably know this, but do you test run your motors before they go back out? IF so, you REALLY need to record that sound!
Old 07-06-2012, 10:34 AM
Engines shipped from my shop re ship dry and untested unless the customer requests a dyno test.
In this case, his race mechanic will tune the engine.
Henry Schmidt
Ph: 760-728-3062
Old 07-06-2012, 11:48 AM
Hello!
is there any chance to have a picture of the center lube cam to chain housing seals. They are known to be unobtanium and never saw one...
Another question, hos did you do to "replicate" the 906 crank? is that something you are able to make on order? if yes, would you send me details by PM?
Thanks a lot!
olivier.
Old 07-13-2012, 04:26 AM
Hello Henry,
Absolutely beautiful work you're doing. Quick question. I thought we were all supposed to use a five or six arm engine yolk to hold the engine on the stand. Yours is just four arm. Any insight?
Thanks.
Dino
Old 07-13-2012, 05:07 AM
up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
Is there anything special to the 906 trans? It looks different from a 901 outside, but the gear stack looks the same. Is that a one-piece bearing retainer? In 1966?
Scott Kinder
kindersport @ gmail.com
Old 07-13-2012, 11:41 PM
Great picture - reminds me of a similar photograph in a very early Honda CB72 manual in a chapter titled 'How to Demolish the Engine'
Old 07-14-2012, 12:26 AM
Beautiful work! Thank you for sharing.
Old 07-14-2012, 08:11 AM
