| It's a trap... |  How long do I bake timing gear to grow for installation?
			How long and at what temp should I bake my timing chain gear off of the aux shaft to get it to slide on the shaft? I'm thinking 15 minutes at 350*  OLD GEAR.
				__________________ Run like the wind, straining the limits of machine and man.... 2006 Atlas Gray Carrera 4, '81 911SC Black on Tan (SOLD), 2006 Acura RSX Type S, '13 Dodge Durango (wifeys). | ||
|  07-06-2012, 01:42 PM |
| It's a trap... |
			Never mind. That was the trick. Slid right on..."Tink".
|  07-06-2012, 01:52 PM |
| Schleprock Join Date: Sep 2000 Location: Frankfort IL USA
			I recently did this on my intermediate shaft.  I heated it with a heat gun while loaed in a two jaw puller.   Took a little while and I had to rap it with a hammer and brass drift a few times to get it to start moving. So I think your 350 degree bake job should do it. Just have the heat gun on the ready because you'll probably lose some heat when you take it out of the oven and run it over to your bench vise to pull the gear.
				__________________ Kevin L '86 Carrera "Larry" | ||
|  07-06-2012, 01:55 PM |
			Sweet.   Nice job!
|  07-06-2012, 01:56 PM |
| Senior Advisor |
			bake 350˚ for 30 min, baste with 30W till tender, let rest for 10 min. slice into 1/4 pieces, enjoy with a side of 1st and 2nd gears. a nice 1987 sweptco would go well with this feast
				__________________ 08 Cayenne Turbo | ||
|  07-06-2012, 04:32 PM |
