too many projects 1983 sc
56 nomad's Avatar
2.2 pitons and cyliner info
rebuilding my 71 t and some of the cylinders are badly pitted is there a way to re-bore and install oversize pistons...does anyone make/ sell them? thanks , ben
Old 07-19-2012, 07:55 PM
911 2.2 T targa
Overzise from Mahle is not available. You can purchase custom oversize from JE or standard oversize from Wössner, but for around the same price (including the work on your old cylinders and new rings) you can get a full P&C set from JE or AA. I personnally bought new Mahle 2.2 P&C's but I don't now if they are easily available in the US and they don't come cheap.
Old 07-20-2012, 02:25 AM
Its easier to buy a used set and you can move up the compression to E which gives you the Brial cylinders.
Bruce
Old 07-20-2012, 04:54 AM
56 nomad's Avatar
Bruce
bruce ,
clarify please..i assume you mean a used set of E P&Cs i thought you could not reuse or bore them as the coating was different etc. after running cost for the up grade with the new pistons what do you think that would be (range)?
i have had no luck buying used P&Cs as i have recently purchased 2 sets that were said to be "within" spec only to find they were within spec for paper weights.
still trying to figure out a good and relatively inexpensive way to rebuild my motor..so any other information would be most appreciated.
ben
Old 07-20-2012, 08:11 AM
Originally Posted by 56 nomad View Post
bruce ,
ben
Hello,
U made same mistakes like i did.
I have bought also used 911 E heads, cylinder and pistons once. Their value was paper weight without doing LOT of machinery. I bought those AA cylinders and JE pistons. They are fitting perfect. My engine is still under construction:-) i will spend one year birthday soon.
After engine rebuilding i am starting renovation body, hope it wont last many years, Brakes and suspension is ok now.
There is now cheap way making engine rebuild when you own Porsche:-)
Old 07-20-2012, 08:57 AM
Ben, you have a PM
Bruce
Old 07-20-2012, 09:11 AM
56 nomad's Avatar
Originally Posted by wtch View Post
Hello,
yes a lot of folks say good stuff but in the end its C@#$ and no return emails....not looking for cheap but reasonable ..i see P/C on ebay for 900 to 3500 thats a big difference at that rate i could buy a 3.0 or 3.2 and do a swap etc. still looking for more information. since i am running webers and stock t cams would moving to the e spec work well or are there other issues involved...like to stay stock and reliable. ben
Old 07-20-2012, 02:58 PM
You can have your cast iron cylinders bored to 85 mm and buy a set of higher compression 85 mm JE pistons.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 07-21-2012, 01:58 PM
Paul_D's Avatar
Ben,
If you can find a good 6th cylinder in the same height group, I have 6 excellent condition Mahle 84mm T pistons and 5 excellent cylinders. Low mileage is documented. I am re-building my 2.2L T engine to S specs. I'm not sure it was such a great idea now that the cost of the upgrade is becoming clear, but... I'm committed at this point.
I had the pistons & cylinders listed in pelican classifieds a couple months ago:
FS: 2.2L Engine Parts w/guarantee
send me email if interested or if you need any more info.
-Paul
Old 07-22-2012, 08:31 AM
Iwent the JE route,bored outthe T cylinders to 2.3l(86.5mm?)Was able to bump the compression to S spec.Bang for the buck.Was able to port the heads n manifolds,get solex cams(Thanks Tom!),bullet proof the caseand rods,and still walk away ahead the game then if I went the mahle route.If youc an live with non oem pistons,pins,and rings,its a viable alternative.Couldnt afford Pauls route(The right way),just way too much coin for a compression bump and birals.Kinda wishI stuck with my stock pistons,they are all within spec.Its nice to have choices!
Old 07-26-2012, 07:50 AM
Grand Am/IMSA Data Guy
Porsche84's Avatar
Anybody got a photo of a 2.2 S piston. I'm dismantling a 71 2.2 engine now and I think the Pistons are "S". The engine has 67 "S" cams. I got the engine from the original owner (71 914-6). The PO did a rebuild many years ago and I think everything is to S specs. The pistons have a high dome and valve relief both sides. Thanks
Jerry Austin
AIM Data Products Dealer
84 911 3.6 track car - Sold
Morris Minor Van with S2000 running gear
http://austinmotorsportsllc.com/
Old 07-30-2012, 05:45 PM
Inside the 2.2 S piston it will say Mahle 84P84 casting.
Bruce
Old 07-30-2012, 06:45 PM
Jerry
Here is a pic of a few 2.2S pistons
Tom Butler
1973 RSR Clone
914-6 GT Clone
Old 07-30-2012, 07:10 PM
Porsche84's Avatar
2.2 S pistons
Thanks Tom and Bruce. My pistons say 89P8+. Do you guys think these are S pistons? The domes look like Tom's photos.
Jerry Austin
Old 07-31-2012, 05:17 PM
Jerry
Your pistons are marked 84P8. These are 2.2S pistons
Tom Butler
1973 RSR Clone
914-6 GT Clone
Old 07-31-2012, 06:58 PM
Old 08-03-2012, 05:10 AM
