need lots of help
this is my girlfriends car, I was driving it when when it took a sh$t... I was at a stop light and when I pushed the gas it sounded like a volts wagon bug and limped into a gas station were it died and would not start.. when I turned it over you could here a clicking sound on the driver side bank.. I have the head off and I can deff see that the exhaust v"s hit the pistons and are now bent and stuck down...?? y would this happen to only one side of the motor?? when all of the timing chains are tight and I cant see anything that is wrong???
Old 07-28-2012, 03:52 PM
Senior Advisor
James Brown's Avatar
sounds like a cam timing failure. (chain jumped, cam timing pin failure) All 3 exhaust valves hit the pistons?
08 Cayenne Turbo
Old 07-28-2012, 04:58 PM
yes all six exhaust vaulves hit not to hard but hard enough... timimg chains can jump teeth??
Old 07-28-2012, 05:03 PM
there were some codes that it threw ramdom misfire and cam shaft position sensor
Old 07-28-2012, 05:08 PM
This sounds like a newer car. Maybe a 996? They have had some issues with the intermediate shaft bearing. If the engine didn't have a problem from a mechanical failure, it was over reved. An over rev will cause the exhaust valves to hit the pistons.
-Andy
Old 07-28-2012, 05:53 PM
ok could it have been over rev earlier in the day and may have done damage that wasn't noticeable for a little while?? because I was at a stop light going like 8 miles an hour ??
Old 07-28-2012, 06:12 PM
Senior Advisor
ok,what kind of car
08 Cayenne Turbo
Old 07-29-2012, 12:13 AM
Targa Time's Avatar
My guess is that if you dont know anything about Porsches and you are removing the "head", this is a CYA operation. Time to face the music, your in the Dog House. Bit the bullet and take it to a reputable shop and have it repaired.
81 Targa, Bamboo Beige, 3.2 SS
Old 07-29-2012, 05:02 AM
Senior Advisor
it's a 2000 996, anyway you look at it-$10,000 to fix min.
08 Cayenne Turbo
Old 07-29-2012, 10:11 AM
Two Rivers's Avatar
My 2.2L lost a fan belt with the PO and the exhaust valves stuck in the guides and bent all six. (slightly)
The engine lost compression and died.
If you had a intake air leak maybe the engine overheated by running lean?
Valkyrie
Old 07-29-2012, 12:17 PM
