do these numbers ring true??
I purchased a rebuilt 1966 911 2.0L engine and would like to know if these numbers ring true for the year?
Cylinder - 80ZD3 Heads - K1819B, R90110430304 Piston - 1030784 Distributor - Bosch 0231 159001 Alternator - D120 400 522 Engine No 900943 Does this all appear to be right for year? Many thanks |
The head numbers work.
Piston should be Mahle 80V37 on the inside casting Bruce |
Thanks Bruce, the piston number I had to get from the top of the piston using an endoscope as engine is complete. The 103 sits above an m and the 0784 is directly below the 'm' marking. The other marking is on the cylinder which is an 'm' above what looks like a three pronged crown???
You ll probably find the correct number inside the piston then.
Bruce |
Cylinder - 80ZD3 - correct
Heads - K1819B, R90110430304 - Correct Piston - 1030784 - should look like attached pic Distributor - Bosch 0231 159001 - Correct Alternator - D120 400 522 Engine No 900943 - A '66 engine should have a S/N starting with 903. S/N 900943 would indicate a 1965 engine ![]()
Tom Butler 1973 RSR Clone 1970 911E - Sold but Never Forgotten 914-6 GT Clone |
Thanks guys, as engine is still together will have to try and view pistons from below with optics. Tom, thanks for date correction.
pistons confirmed
Thanks Bill, confirmed tonight with endoscope that i have the piston pictured above. Found the casing numbers which are 133/133. So it looks like a have a pretty original rebuilt motor.
endoscope
what brand of endoscope did you use?
1975 911S Targa Silver Anniversary Edition |
litetec
