duke of boots's Avatar
do these numbers ring true??
I purchased a rebuilt 1966 911 2.0L engine and would like to know if these numbers ring true for the year?
Cylinder - 80ZD3
Heads - K1819B, R90110430304
Piston - 1030784
Distributor - Bosch 0231 159001
Alternator - D120 400 522
Engine No 900943
Does this all appear to be right for year?
Many thanks
Old 09-23-2012, 03:07 PM
The head numbers work.
Piston should be Mahle 80V37 on the inside casting
Bruce
Old 09-23-2012, 05:12 PM
Thanks Bruce, the piston number I had to get from the top of the piston using an endoscope as engine is complete. The 103 sits above an m and the 0784 is directly below the 'm' marking. The other marking is on the cylinder which is an 'm' above what looks like a three pronged crown???
Old 09-24-2012, 04:23 AM
You ll probably find the correct number inside the piston then.
Bruce
Old 09-24-2012, 05:18 AM
Cylinder - 80ZD3 - correct
Heads - K1819B, R90110430304 - Correct
Piston - 1030784 - should look like attached pic
Distributor - Bosch 0231 159001 - Correct
Engine No 900943 - A '66 engine should have a S/N starting with 903. S/N 900943 would indicate a 1965 engine
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 09-24-2012, 05:54 AM
Thanks guys, as engine is still together will have to try and view pistons from below with optics. Tom, thanks for date correction.
Old 09-24-2012, 07:17 AM
pistons confirmed
Thanks Bill, confirmed tonight with endoscope that i have the piston pictured above. Found the casing numbers which are 133/133. So it looks like a have a pretty original rebuilt motor.
Old 09-25-2012, 01:52 PM
47silver's Avatar
endoscope
what brand of endoscope did you use?
1975 911S Targa
Silver Anniversary Edition
Old 09-25-2012, 02:10 PM
litetec
Old 09-25-2012, 02:23 PM
