304065's Avatar
What parts are unique to a Turbo motor?
What are the major parts that differ, for example, between a CIS 3,0, a Motronic 3,2, and a Turbo motor? I don't need exact part numbers, but just examples of the major systems that are different, and how are they different.
Examples I can think of
Pistons
Oil pump
Isn't there some kind of turbocharger oil pump? Etc.
Thanks!
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 10-19-2012, 10:35 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Piston squirters- more volume for 930
Heads use a different alloy, valves are different Turbo vs. N/A
Cams (typical upgrade is to install SC cams)
Head studs are all dilivar
Clutch (240mm vs 225mm- until G50 came along)
Crank pulleys are different
Cylinders- fins or different alloys?
Engine case scavenge line- different exhaust manifolds prompts different oil path
Oil tank- has extra fitting for turbocharger scavenge pump
930 engine has an oil separator
930 has a different air injection system (exhaust)
Kevin L
'86 Carrera "Larry"
Old 10-19-2012, 12:25 PM
John
Here is a quick, from memory, comparison
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 10-19-2012, 12:47 PM
Kartoffelkopf
Spenny_b's Avatar
Why the question John, you thinking of dropping a hot rod lump into the '69?
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html
On Instagram (along with other stuff) as @spenny_.b #spennybengineproject
Old 10-19-2012, 01:52 PM
Kartoffelkopf
Spenny_b's Avatar
A few more for the list:
- The turbo (ho ho)
- Wastegate
- Recirc valve
- The oil feed line to the turbo, from a feed on a gallery between the crankcase chimney and thermostat cover.
- Oil drain tank for the turbo
- The auxiliary turbo scavenge pump (at back of 1-3 cam)
- Single 6-plug dizzy - later n/a's ran dual 6-plug dizzys
- Single plug heads vs later heads that were twin plugged
- The A/C pump stabiliser/support brace....interferes with N/A fuel rail...ask me how I now know.
- Don't know if N/A CIS is the same as Turbo CIS....as you know, I'm not clever, or interested enough to understand the minutae of the Turbo CIS system....(reckon a Tourbillon movement would be easier to understand)...control valves, anti-runon valve, recirc valve, cold start valve, secondary air gate, WUR, frequency valve, cold start injector, thermo time switch....
- Intercooler (apart from the early Turbos) with boost pressure sender and fuel cutout switch
- No knock sensors up to 964 (not sure if 993T ran them, quite possibly)
- Very coarse (crude) crank position sensor, not the later 60-2 teeth pattern on the flywheel.
- The 964T has its oil filter mounted behind cyl 2-4 where the N/A motors have their oil cooler matrix.
- Exhaust valve covers are more rigid on Turbo
- Engine mount bar; mine is different from the same vintage N/A item
- Engine mount cover; N/A items (IIRC) have an access hole at the front to be able to turn over the crank, Turbos (well, certainly the 964 vintage) has a solid cover, no cutout.
- Do N/A run two fuel pumps, front and rear?
Sure I'll think of more whilst tinkering tomorrow!
Cheers
S
Old 10-19-2012, 03:50 PM
