Carbon Emitter
jkarolyi's Avatar
Any alternatives to the $1000 '87-'89 G50 Sachs clutch kit?
Planning to drop my engine for some performance mods and was checking out my options for clutch kits as a "while you're in there" project.
The original Sachs kit is just under $1000 here on Pelican! Are the clutch linings made of titanium or something? My guess is that there is a limited customer base for them because not many 911s were made from 1987-89.
Are there any other good options on the market, or is Sachs the only game in town? I heard that 911 Turbo clutch kits will interchange...true?
Thanks for any help,
Old 04-26-2007, 02:56 PM
buttjoint's Avatar
You will want to use the spring center disc. the correct presure plate, and fly wheel. Make sure the g50 up date has been done.
Old 04-26-2007, 03:06 PM
Carbon Emitter
jkarolyi's Avatar
Yep...mine had its clutch replaced around 65,000 miles, at which point the G50 update was done. The car has 140,000+ miles on it now. The spring-centered kit is still $950. Nobody else makes a clutch kit for these? Hate to be a cheapskate, but this seems to be a ridiculous price for a common wear item.
Old 04-26-2007, 03:29 PM
charleskieffner's Avatar
centerforce
Old 04-27-2007, 06:19 AM
Carbon Emitter
jkarolyi's Avatar
Thanks for the alternative, but that one costs $1200! Is this the going rate of clutches these days? I replaced one in my old 944 Turbo (with about the same HP going through it) for $200 about 10 years ago.
Old 04-27-2007, 09:16 AM
im sure you can find one in calif. but if pelican doesnt have, patrick motorsports does.
hot poop ticket and thats what im doing. hey how many times do you want an engine drop party?????
ran centerforce on my old prerunner off road racing. never a problem. stock clutches we ate them alive!
Old 04-27-2007, 09:23 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Kennedy engineering offer a plethora of clutch options from street to track. 661-272-1147.
Pelican Parts may offer Kennedy products through their online catalog
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 04-27-2007, 12:04 PM
KTL KTL is offline
Schleprock
KTL's Avatar
clutch kits for these cars are indeed not cheap and you're right the options are limited due to the exclusivity of the 87-89 G50, on top of it being a Porsche and thus subject to the "Porsche tax." Be it Spec, Centerforce, OE Sachs, or whoever, you're going to pay a good buck for a complete kit. So if you can get away with reusing your clutch housing, by all means do it.
For that kind of money, i'd heed Henry's advice and look into a Kennedy LW clutch housing. The OE clutch housing is mega heavy and the savings in weight is more in the clutch housing than the flywheel. I've got one (to be installed soon) and I can tell you it's a substantial savings in weight. The downside is the weight loss can affect idle stability and possibly cause stalling on abrupt throttle closure. The surefire way to avoid the stalling is to have a ECU chip that acknowledges the presence of the light clutch housing
For a complete performance clutch overhaul in street & light track form, i'd recommend:
Kennedy LW clutch
resurfaced flywheel with new pilot bearing
spring center disc
new release bearing
new guide tube (if heavily worn or the old, outdated size)
thorough inspection of release fork pivot points- lube as needed
You can get crazier if you want with different types of discs but that's more money and not worthwhile if the car is street driven only. Check out Spec's website for more detail
www.specclutch.com
Kevin L
'86 Carrera "Larry"
Old 04-27-2007, 06:09 PM
AlfonsoR's Avatar
Subscribed
Old 12-28-2012, 12:52 AM
I thought I'd seen some reasonably priced alternatives if going with the Turbo option on the G50 but it was a long time ago and I don't recall the details. I'm interested b/c I assume at some point I'm going to have to replace my clutch, which was upgraded to the Turbo.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 01-03-2013, 07:50 PM
AlfonsoR's Avatar
This is an old thread that I brought up only because I did not see a feature to subscribe from my iPhone, so, sorry I did not mean to bring it back up.
On the other hand, it's been a while since last informational post so if anyone has some good info to share, i'm all ears too.
"Simplicity is supreme excellence" - James Watt
Old 01-03-2013, 11:56 PM
KTL KTL is offline
Schleprock
KTL's Avatar
The only OEM Turbo option for the G50 is the 3.0 930 (1975-1977) clutch disc. The Turbo clutch housing is not a direct interchange for the G50, despite it being the same 240mm size as the G50.
It seems that spring discs have become the norm for the G50 clutch kits. The rubber center discs must have been phased out?
Clutchnet.com makes some good stuff. I've used their discs with good success on my racecar. They usually have good winter discounts too.
Clutch Kit Package
Kevin L
'86 Carrera "Larry"
Old 01-04-2013, 09:44 AM
